Enthusiast ![]() ![]() Joined Dec 23, '10 From PA, USA Currently Offline Reputation: 0 (0%) ![]() |
I'm dropping my car 2" soon but keeping with the stock GT wheels. Can I put spacers on to stick them out? Anyone got any pics? Also how big of a spacer can I do? |
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 11, '08 From Auckland, New Zealand Currently Offline Reputation: 0 (0%) ![]() |
Ive worked out for my stock 7.5" wide wheels with 225 tyres, the maximum is 25mm in the rear and 20mm up front. this may still require rolling of the inner lip
this combined with my stock offset of ET45. -------------------- Mike W
With 205's you may have another 10mm to play with more than i will, if running 215's then only up to 5mm more than i do.
Whatthe talks about his spacer and hella flush issues in his thread, I think with stock 7th gens. -------------------- Mike W
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) ![]() |
Been running GT rims on my spacers
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Any pics?
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) ![]() |
Im running spacers (25mm) on stock gts wheels, rear had to be rolled, running 205's though
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
![]() -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
That looks good. What size spacer is that? What else needs to be done with the spacers, longer studs? |
2 left hand studs, 3 right hand studs, a couple washers, green thread lock, and cross drilled brake lines
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) ![]() |
![]() 20mm spacers all around -------------------- |
Enthusiast ![]() ![]() Joined May 30, '05 From MN Currently Offline Reputation: 8 (100%) ![]() |
Nice!! Thats what I have on mine as well for about 6months now. Had to get a different acorn nuts that are a tad longer though( 0.8inch length). The ones that came with the spacers have the tendency to get rounded easily if you are not careful with tightening and removing them. Found out the hard way.
-------------------- 3sgteing.
..burns twice as bright, lasts half as long. "The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction." -Allen Ginsberg- |
Lo-Fi Version | Time is now: February 16th, 2025 - 1:22 PM |
