> glowshift gauges, installation
post Apr 25, 2011 - 1:23 AM
dee_y
Joined Feb 26, '11
From maryland
hey looking to get some new gauges a oil pressure,vacum,volts but i have no idea on how to install them any help...pictures woould help alot...
post Apr 25, 2011 - 2:22 AM
zonz540
Joined Jul 3, '09
From UT
Oil pressure sensor is on the upper left of the motor, tap any 12v (+) constant line for the volt meter.
Id pull from the constant 12v (+) in the steering column. Heres the wire colors for 94-99 celicas.
Toyota Celica Alarm, Remote Starter, Keyless Entry Wiring Information
Constant 12V+ White or Black/Red Ignition Switch Harness
Starter Black/Yellow Ignition Switch Harness
Ignition Black Ignition Switch Harness
Ignition 2 Blue/Red Ignition Switch Harness
Tach Gray Check Connector
Brake Switch Green/White Brake Switch or Driver's Kick Panel
Trunk Pin Blue/Yellow (-) Driver's Kick Harness (Junction Block)
Parking Lights Dark Green (-) Dimmer or Fuse Panel
Head Lamp Red/Black (-) Light Switch
Door Trigger Red/White (-) Driver's Kick Harness Running to Trunk
Door Lock Blue/Black (-) Door Lock Module right of Steering Column
Door Unlock Blue (-) And Green use Both Wires Diode Isolate
Horn Wire Green (-) Steering Column
Windows Up LF=Green, RF=Green/White LR=Green/White, RR=Green
Windows Down LF=Red, RF=Red/Blue LR=Red/White, RR=Red
Toyota Celica Stereo Wiring
Constant 12V+ Blue/Yellow
Switched 12V+ Gray
Ground Brown
Illumination Green
Dimmer n/a
Antenna Trigger Black/Red
Antenna Left Rear
Front Speakers 6 1/2" Doors
Left Front (+) Pink
Left Front (-) Purple
Right Front (+) Light Green
Right Front (-) Blue
Rear Speakers 6 1/2" Side Panels
Left Rear (+) Black
Right Rear (+) Red
Right Rear (-) White
post Apr 25, 2011 - 9:21 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
I'd stay away from glowshift. They're cheap and notoriously inaccurate.
**** Photobucket
post Apr 25, 2011 - 12:05 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
I have glowshift, have not had a single problem with them, everyone bashes them without ever using them
2001 Solar yellow Lexus IS300
post Apr 25, 2011 - 11:00 PM
95CelicaST
Joined Feb 5, '05
My buddy had them in his Honda. We threw them away and installed stri gauges.
If I were to buy cheap gauges I would get Prosports...
**** Photobucket
Lo-Fi Version Time is now: February 19th, 2025 - 9:37 PM
