> Best spark plugs for 7AFE
post Apr 25, 2011 - 2:27 AM
conus00
Joined Jul 10, '08
From Tampa, FL
As title says: what are the best spark plugs for stock 7AFE?
'94 ST
post Apr 25, 2011 - 2:33 AM
Hanyo
Joined Aug 16, '03
From Bay area
ngk or denso.
doesn't matter if you got copper or iridium, you will not notice a difference.
post Apr 25, 2011 - 5:50 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
go with E3's a bit pricey but worth it
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Apr 25, 2011 - 9:58 AM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
I got Platinum NGK G-Power. Didn't notice a difference like Hanyo said lol. But they've worked perfect. Remember, gap for 7AFE plugs is 0.028". There's no such thing as "pre-gapped".
June '12 COTM
'95 AT200
post Apr 25, 2011 - 11:19 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (HectortheRican @ Apr 25, 2011 - 7:58 AM) *
iridium plugs are pre gapped, you dont put feeler gauges in there to check because you take a chance of damaging the tip.
.028 is really tight, are you sure thats what it is? thats a gap for a turbo car, not a stock 7A-FE
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Apr 25, 2011 - 12:48 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Smaay @ Apr 25, 2011 - 10:19 AM) *
100% positive. My repair manual said so and that's what a few online references said too. And you never use feeler gauges to gap Platinum or Iridium. You use the wire gappers, they don't damage the tip at all.
June '12 COTM
'95 AT200
post Apr 25, 2011 - 8:49 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
dang that tight for an NA car.
post Apr 25, 2011 - 8:51 PM
HectortheRican
Joined Dec 26, '09
Yeah, that's what I thought as well. And the gap for 5S was 0.044", iirc? That seems like a really big difference.
June '12 COTM
'95 AT200
post Apr 26, 2011 - 6:56 PM
kormysh8
Joined Nov 14, '09
From Saskatoon
Correction. The spark plug gap for a 7a is .032 inch
post Apr 27, 2011 - 11:15 AM
conus00
Joined Jul 10, '08
From Tampa, FL
So if the plug gap is 0.032 inch will these work:
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEWAX%3AIT
(1.016mm = 0.04in, is that close enough?)
'94 ST
post Apr 27, 2011 - 12:01 PM
HectortheRican
Joined Dec 26, '09
QUOTE (conus00 @ Apr 27, 2011 - 10:15 AM) *
Still gotta gap them
June '12 COTM
'95 AT200
post Apr 27, 2011 - 2:19 PM
Hanyo
Joined Aug 16, '03
From Bay area
Spark plugs are "pre-gapped". If you buy the right ones they will be gaped to the specs of your car, however they tend to change gap as they get bumped around in shipping. Therefore you have to gap them. If you look under the spark plug reference chart they list the gap for your spark plugs.
http://www.ngksparkplugs.com/part_finder/c...suv/results.asp
Additionally some denso spark plugs can not be gapped.
those are the oem spark plugs for some Toyota's, not the bs +4 bosch spark plugs.
here is another example if spark plugs that can not be gapped:
QUOTE (Smaay @ Apr 25, 2011 - 9:19 AM) *
iridium plugs need to be gap also. But 99% of the "shade tree mechanics" don't know how to gap them. Therefore many part stores market them as "pre-gaped" to save people from the head aches of damaged spark plugs.
people use ramped spark plug gap tools to open the gap on the spark plugs which is the wrong way to do it. Every time you gap each plug you end up cutting into gapper tool which changes the reading. The ramp gapper tool is a measuring device and not a tool used to open up the gap.
Its like using a ruler as a knife and then complaining that you no longer can trace straight lines. That is why the wire gaper tool is recommended because it reduces the human error factor.
The right way to gap spark plugs is to use pliers. specifially these:
With all this technical jargon out of the way, what would i recommend? Well first things first always check the gap of your spark plugs. Your goal is for all of them to be the same gap around .030 in. If you notice one is gapped smaller then the rest exchange them with your parts store. Do not worry too much about the gap, as this changes as they wear out. They will open up was they the electroid wears or close down as they collect carbon. If your super anal you can adjust them but 90% of the time you will not notice a difference. That is why those crazy bs bosch +4 spark plugs can work in any car.
post Apr 27, 2011 - 2:38 PM
conus00
Joined Jul 10, '08
From Tampa, FL
So, if I understand you correctly, you are saying that if I buy set of four plugs I posted in the link, the gap difference of 0.008 in will not make a difference and they will work just fine?
'94 ST
post Apr 27, 2011 - 2:52 PM
Hanyo
Joined Aug 16, '03
From Bay area
QUOTE (conus00 @ Apr 27, 2011 - 12:38 PM) *
post Apr 27, 2011 - 3:30 PM
HectortheRican
Joined Dec 26, '09
Those scissor things look very expensive.
You can get these for less than $2 and they do not hurt the core unlike the ramped gappers. I use a ramp gapper to measure and this one to actually do the gapping.
June '12 COTM
'95 AT200
post May 9, 2011 - 2:03 AM
celica-s
Joined May 9, '11
From Manila, Philippines
I'm using IX NGK iridium plugs. works well here. getting good milleage too.
post May 9, 2011 - 10:59 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
i use plain old NGK BKR7ES plugs. i buy them in bulk and use them in every one of my cars.
This post has been edited by Smaay: May 9, 2011 - 10:59 AM
Lo-Fi Version Time is now: December 2nd, 2024 - 1:46 PM
