help me to name this broken part, how is it called ???????? |
Apr 25, 2011 - 8:34 AM |
Enthusiast Joined Jan 1, '11 From uk Currently Offline Reputation: 3 (100%) |
hi how is it called in english that broken rubber behind my front right wheel ? its look like i need to change it ohh is just the rubber or is it something else as well ??
Uploaded with ImageShack.us |
Apr 25, 2011 - 8:41 AM |
Enthusiast Joined Jan 20, '10 Currently Offline Reputation: 1 (100%) |
cv boot is split,does the joint make any noise?esp on full lock driving slowly..?if so it will need a new joint..
Make sure you put some grease in it also as it prob lost some.. could also be called outer drive shaft gator.. This post has been edited by bigb1970: Apr 25, 2011 - 8:44 AM |
Apr 25, 2011 - 8:48 AM |
Cheers Brian ,Joint is fine i think ,didnt hear nothing really .many thanks i go check ebay now
Apr 25, 2011 - 9:10 PM |
Enthusiast Joined May 6, '08 From Lisarow, NSW, Australia Currently Offline Reputation: 0 (0%) |
Just buy it from an auto shop, its the inner cv boot, shouldn't be more than $10, good luck!
Apr 25, 2011 - 9:33 PM |
Enthusiast Joined Mar 26, '10 From Portsmouth, OH Currently Offline Reputation: 2 (100%) |
thats definitely the outer cv boot (look at the brake line, a-arm, and angle of the axle). if it was the inner you would be better off just getting the whole axle assembly because that boot is a b***h to get off and on. since its the outer though, replacement is fairly quick, easy, and cheap.
Apr 27, 2011 - 8:49 PM |
Enthusiast Joined Apr 11, '09 Currently Offline Reputation: 11 (100%) |
id leave it alone, i drove with mine like that for 2 years no problem. just saying of course.
Apr 27, 2011 - 9:22 PM |
id leave it alone, i drove with mine like that for 2 years no problem. just saying of course. Don't follow this advice, that's the stupidest idea ever. You want to get this fixed as soon as possible before it gets worse. Just go to an auto store and order a new one, shouldn't be more than $125 for an axle |
Apr 27, 2011 - 9:48 PM |
u really dont need a whole new axle, just a cv boot... outer cv boot is like $10-$20 at an auto parts store... as long as there is no popping sound, like pop cans, then the cv joint is fine, the boot just needs replaced
Apr 28, 2011 - 3:22 AM |
Axle is fine ,no weird sounds ,idea to drive without fixing it is silly mate ,just ordered cv boot for 10 quid will fit it in the weekend
.cheers guys |
May 10, 2011 - 8:10 PM |
Enthusiast Joined May 9, '11 From Manila, Philippines Currently Offline Reputation: 0 (0%) |
Replace the boot and don't forget to grease it.
Lo-Fi Version | Time is now: November 27th, 2024 - 4:33 PM |
