> Issue with Battery and starter motor, problem sorted, faulty starter
post Apr 27, 2011 - 11:16 PM
PolliS_5S-FE
Joined Aug 29, '08
From Auckland, New Zealand
Hi guys. So as an addition to my initial problem of code 12 coming up I now have a problem with my battery doing some massive sparks and melting the negative terminal when the starter motor is connected and. When its disconnected the negative terminal connects fine with minimal sparking. I've checked the connections on the starter and everything seems to be ok.. Does this mean I need a new starter?
This post has been edited by PolliS_5S-FE: May 1, 2011 - 7:22 PM
post Apr 28, 2011 - 12:32 AM
fuse panel.
post Apr 28, 2011 - 1:51 AM
PolliS_5S-FE
Joined Aug 29, '08
Thanks batman, checked the fuse and its fine
This post has been edited by PolliS_5S-FE: Apr 28, 2011 - 6:11 PM
post Apr 28, 2011 - 5:18 PM
PolliS_5S-FE
Joined Aug 29, '08
bump
Lo-Fi Version Time is now: January 10th, 2025 - 12:46 AM
