6 Pages V  « < 2 3 4 5 6 >
> Rhode Island Project Celica
post May 26, 2011 - 10:52 PM
Ted95
Joined Mar 8, '09
From Westport, MA
good luck.
st205 powered ss3 coupe
post May 26, 2011 - 11:16 PM
mkernz22
Joined May 10, '10
From MA
same man, and my clutch went. can't help you out.
post May 27, 2011 - 1:13 AM
Culpable04
Joined Apr 17, '06
From New Jersey
QUOTE (LimitedGT4 @ May 26, 2011 - 5:31 PM) *
i dnt plan to spend or have the time to spend10 hours
For somethin someone can answer in 10 secs
Thanks for your contribution
open wide, spoon is on its way.
the reason why not many have experiences with the stock clutch, is because is a royal pain to replace it after the engine is installed, why run the risk of wanting more power down the road and trashing a brand new clutch because it wasnt desing for that amount of power ? yes, I read you said you dont want more than stock, that's what most people say when swapping their engines, and 3 months later the car starts to feel slow again, and power is a boost controller away.
I may have mis advised you before, reading deeper into your answers, you should keep looking for someone to do it for you that's if you want the car to run again. unless you are willing to spend countless hours reading and reading and then doing some reading, you better get that checkbook ready.
This post has been edited by Culpable04: May 27, 2011 - 1:14 AM
post May 27, 2011 - 1:17 AM
Culpable04
Joined Apr 17, '06
From New Jersey
BTW, I sent you a PM with something you are looking for, that's how unfriendly and unhelpful we are around here
post May 27, 2011 - 6:34 AM
LimitedGT4
Joined Apr 18, '11
From Southern Alabama
now i know.
This post has been edited by LimitedGT4: Jun 11, 2011 - 6:34 PM
post Jun 11, 2011 - 6:49 PM
LimitedGT4
Joined Apr 18, '11
woooooo, the MEET at CSP wat GREAT if you missed it you missed it
anyways, some pics
post Jun 11, 2011 - 7:06 PM
Ted95
Joined Mar 8, '09
From Westport, MA
it was def a good time bro, and im really likein those break brotha lol
This post has been edited by Ted95: Jun 11, 2011 - 9:40 PM
post Jun 13, 2011 - 7:25 PM
LimitedGT4
Joined Apr 18, '11
something i did to my lights
sorry mike had to do it they look amazing man hope urs come out the same
so i asked mike, Mike how did you open your headlights? and he said boilem so i did
then i opened them like a clam and took a peak
took off the bezel and painted them black biggrin.gif me like
post Jun 13, 2011 - 7:52 PM
mkernz22
Joined May 10, '10
From MA
Mine look the same! I did all 4 wink.gif My low beams look amazing with the accent lights in them
post Jun 13, 2011 - 11:30 PM
Ted95
Joined Mar 8, '09
From Westport, MA
post Jun 17, 2011 - 8:37 PM
LimitedGT4
Joined Apr 18, '11
sooo today i pulled my ECU and this is what i found confused.gif tongue.gif woot.gif
for those that know u know and thos that dont google it its a quick wikipedia or check the link below
http://www.rpmgarage.com/new/detail/?tid=11224
post Jun 17, 2011 - 8:45 PM
mkernz22
Joined May 10, '10
From MA
aren't you f*cking lucky!!!
post Jun 17, 2011 - 8:49 PM
LimitedGT4
Joined Apr 18, '11
dude if i ever decide to build another celica ITS FULL FRONT CLIP ALL THE WAY DEFINITELY WORTH EVERY PENNY paid 3500 got parts upwards of 6000
ok so found this on a forum
if you google 89661 2b840, you will note that this is a hacked '94 / '95 JDM ST205 ecu.
essentially like all these types of pnp ECU, it will have a raised RPM and boost cut and will run best of high octane fuel. It is not re-mappable and only good for light breathing mods eg exhaust & flter
NOTE:
# You DO NOT need an uprated fuel pump eg walbro 255 lph or equivalent. (This will casue overfuelling, despite having a FPR)
# You DO need a ST205 or SW20 rev3 3sgte denso fuel pump @ 225 lph.
# You DO need ST205 / SW20 540cc low impedance side feed injectors.
# You DO need ST205 electronics: MAP sensor, igniter, IAT etc
ill take a wild guess that being that the car was running with this ecu i probably have all the parts the engine needs to accomodate this ecu but they say not to use a walboro pump, who knows more about this ecu ill continue to research THIS IS PART OF MY RESEARCH LOL j/k but any input is appreciated,
only want to know about the walboro fuel pump overfeeding
This post has been edited by LimitedGT4: Jun 17, 2011 - 8:56 PM
post Jun 18, 2011 - 12:27 AM
Ted95
Joined Mar 8, '09
From Westport, MA
thats sickk bro good for you man!
This post has been edited by Ted95: Jun 18, 2011 - 12:35 AM
post Jun 18, 2011 - 10:40 AM
NYp8tBaller07
Joined Jan 30, '11
From Albany, NY
Sweet treasure you found there Arrrrr!
Power in Balance
90 ST coupe- Sold
95 ST hatch- Dead :’(
02 Impreza RS- DD
post Jun 19, 2011 - 9:58 AM
wow.
what a thread.
now, i must admit, i havent looked at this thread really at all untill this morning, but from meeting you at CSP, i definetly wouldnt have thought you'd be this rude.
these guys are telling you to research over and over for a REASON.
you want everything spoon fed for you, like stevenson said, but even if we do spoon feed you, your still gonna be lost when it actually comes time to DO somthing, cause you arnt actually LEARNING anything.
these guys that are telling you all this stuff are guys who HAVE done the research, and taken the time to learn how to and perform theyre own swaps.
youve met cam, ask him what he has gone thru over the past YEAR researching his swap, then ask him how hard reality slapped him in the face when it came time to actually DO it.
without the help of dustin and steff, he would have been LOST, and not because he didnt research and take the time...its because he's never done it. like you.
untill you've actually done somthing, all this talk is just that, talk, but the more you actually take the time to do the research and learn as much as you can now, the more prepared you'll be when you run into the little hiccups that come with ANY swap.
if you cant handle that, you better be prepared to spend ALOT of money to do things twice, and expect lots of problems along the way.
good luck.
post Jun 20, 2011 - 12:29 AM
RabidTRD
Joined May 31, '11
From Rochester, NY
QUOTE (LimitedGT4 @ Jun 13, 2011 - 8:25 PM) *
Did you hold them in there the whole time or just dunk them? I've been planning on painting the bezels for a while now and just haven't gotten around to doing it. I've heard of the baking method, but I'm scared the rubber may melt. Please advise.
How do they look on your car?
post Jun 20, 2011 - 10:02 AM
LimitedGT4
Joined Apr 18, '11
QUOTE (RabidTRD @ Jun 20, 2011 - 12:29 AM) *
After the water is boiling just dip tyem for about a minute or so and see if its easy to pry them off if its a lil to hard still dippem again until they are easy to work with and ill upload a picture wen i get on but they look nice
post Jun 21, 2011 - 3:06 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
The sudden heat doesn't crack the lens? That's all I'm worried about.
post Jun 21, 2011 - 4:10 PM
LimitedGT4
Joined Apr 18, '11
QUOTE (RabidTRD @ Jun 21, 2011 - 3:06 PM) *
Cant guarantee that but i can say it didnt happren to me
Lo-Fi Version Time is now: February 25th, 2025 - 7:09 PM
