> 3rd Gear, Hard to get in?
post May 3, 2011 - 1:33 AM
TheChildOfTheSea
Joined Dec 7, '10
Sometime I find my 3rd gear hard to get in...is it normal? I remember having this issue with my MSP with 2nd gear...
Maybe because I'm not used having a normal shifter? (The MSP was my first m/t car and had a short shifter from factory)
Edit: Forgot to specify I have a 6 point ceramic clutch is this information could be useful
This post has been edited by TheChildOfTheSea: May 3, 2011 - 1:36 AM
post May 3, 2011 - 1:45 PM
PhoenixTech
Joined Dec 3, '08
From Summerville, SC
I doubt the shifter has anything to do with it. Short shifter vs stock is just the distance your hand travels to shift the gears. Anyway, Make sure your transmission has the correct amount of fluid in it, sometimes low fluid levels can cause hard shifting. Also make sure that your clutch master cylinder has the correct fluid level in it as well. These are just things to check for good measure, but it really sounds like your synchro might be going out. Does it shift hard all the time, or only on quick shifts?
-Cam
www.tweakdperformance.com
sales@tweakdperformance.com
post May 3, 2011 - 2:27 PM
TheChildOfTheSea
Joined Dec 7, '10
Only on quick shifts!
post May 3, 2011 - 3:39 PM
PhoenixTech
Joined Dec 3, '08
synchro.
post May 3, 2011 - 4:31 PM
TheChildOfTheSea
Joined Dec 7, '10
QUOTE (PhoenixTech @ May 3, 2011 - 4:39 PM) *
synchro.
How can I fix that?
post May 3, 2011 - 4:39 PM
Soulend
Joined Nov 24, '07
From Tucson, Az
its really work intensive, and your car will be off the street for a few days if you do, do it. basically you need to take the trans mission off, then the transmission housing... imho if you usually don't work on cars, have someone do it for you.
Kevin
This post has been edited by Soulend: May 3, 2011 - 4:39 PM
post May 3, 2011 - 6:26 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
be lucky 3rd works wink.gif mine only will work say rolling at 20mph in second and for the hell of it you go into 3rd...try it going say 35 and go into 3rd will sound like your slaughtering a pig or something lol so my advice to you is plan to swap trans or do a swap.... depending on cash flow of course..... just know in the future your trans will need to be replaced....id start saving...good luck to ya
This post has been edited by opie_7afe: May 3, 2011 - 6:30 PM
post May 3, 2011 - 7:33 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I had a slight grind on 3rd with I shift semi quick, if quick shift I wouldn't notice it, and wouldnt notice it during normal shifting either, and 4th would pop out during quick shift, I played a little with my clutch pedal height and engagement and it's all good now. no more issues on any type of shifting.
so that's something else to look at.
post May 3, 2011 - 7:45 PM
mkernz22
Joined May 10, '10
From MA
my first gear doesn't like to go in a lot, i'm talking about being at a complete stop. sometimes its fine, other times its not and i really have to jam it in there
post May 3, 2011 - 8:27 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
oh yeah to the OP try draining your trans and refilling it with some synchromesh might help read it does help and sometimes prolongs the inevitable
post May 4, 2011 - 2:24 AM
TheChildOfTheSea
Joined Dec 7, '10
Yeah the trans oil was changed recently!
I think the problem was in my head...I tried it again today and I didn't have this problem...maybe I was just hitting the wall (trying to shift between the 3rd and 5th gear instead)
post May 4, 2011 - 6:59 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
does it feel like its entering the gate or a mushy feeling?
if its not entering the gate then its gonna be with the trans/clutch itself. but if it feels mushy and not entering a gate then id look into your shifter cables.
if its your shifter cables you'll soon not have 5th then 4th, 2nd gearings almost in that order
post May 5, 2011 - 9:28 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (808celica @ May 4, 2011 - 6:59 AM) *
I find that 2 quarts syncromesh and 1 quart Lucasoil do wonders. I can now shift into first before stopping, and my 5th gear popout has stopped. But I will need a tranny someday. Also I blead my clutch slave and the oil looked like it was black ink and water so I think that would help. The little self bleeder from autozone(about 7.99) makes that a simple job.
post May 5, 2011 - 9:35 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (xrav22 @ May 5, 2011 - 10:28 AM) *
I've heard you're not really suppose to shift into first while still moving because it can start to screw with the transmission after a while. My first gear is a pain to get into even when at a stop sometimes. I'll try what you did in the future and see how it works because it starts to piss me off when it takes a few seconds to get it into gear and people behind you start beeping lol
post May 5, 2011 - 2:13 PM
TheChildOfTheSea
Joined Dec 7, '10
The reason why you can't shift in first while still moving is because of the 1st gear guard, it's to prevent you downshift back in first instead of third. My transmission does this too...in traffic I always have to stop completely, and it forces me to do my stops at full time.
post May 5, 2011 - 11:03 PM
Needles
Joined Nov 18, '10
From montreal
QUOTE (TheChildOfTheSea @ May 5, 2011 - 3:13 PM) *
lol really ? try to down,,shift to first gear at higher RPM , it should shift easely biggrin.gif or maybe not, lol
This post has been edited by Needles: May 5, 2011 - 11:05 PM
post May 6, 2011 - 9:22 AM
mkernz22
Joined May 10, '10
From MA
QUOTE (Needles @ May 6, 2011 - 12:03 AM) *
why dont you try it when you get your car running.
Lo-Fi Version Time is now: November 27th, 2024 - 4:54 AM
