> 3sgte in 3sge
post May 5, 2011 - 2:10 AM
makgt
Joined May 2, '11
From manchester uk
hi i guys i'm new to celica family i got ma self a celica gt st202 not long ago as a project and i was thinking if i can swap ma standard engine to st205 also if i can what do i need? thanks guys
post May 5, 2011 - 2:24 PM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
ST205 engine complete with loom and ECU. Its Plug and play in a ST202 with a 3SGE. Your std gearbox will be OK as long as you do not go crazy with engine output. You will have to use a ST202 performance drive plate with ST205 pressure plate. Another option would be to use the ST202 flywheel with a performance clutch assembly. You will need beter brakes. 3SGTE downpipe mated to a performance ST202 system. STD fuel pump will do as long as the engine is std, but its easy to replace as its under the rear seat. Go through your whole suspension, make sure that its all in good order as increased performance will show it weakness. Also use a ST205 fuel filter as the std GT one is smaller.
post May 5, 2011 - 5:30 PM
makgt
Joined May 2, '11
From manchester uk
QUOTE (jeffrosie @ May 5, 2011 - 3:24 PM) *
post May 5, 2011 - 5:35 PM
makgt
Joined May 2, '11
From manchester uk
thanks for the info mate i found this guy who selling everything i need for £1000 and can i uce gt4 brake discs and calipers on st202 as and upgrade?
Lo-Fi Version Time is now: December 4th, 2024 - 2:41 PM
