> need help, body kit on 97
post May 5, 2011 - 8:10 AM
chris26
Joined May 5, '11
From denver co
i have been working on installing a new body kit after getting the new front fenders on the hood over laps the passenger side by about a 1/2 inch on the front and its even on the back how do i fix this? thanks
post May 5, 2011 - 8:59 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Fiberglass fenders, I presume?
You need to work on aligning them. Loosen up the bolts and pull the fender ou. I doubt you'll get 1/2 inch, so you might need to elongate the bolt holes. Does the hood line up fine on the drivers side?
**** Photobucket
post May 5, 2011 - 9:01 AM
chris26
Joined May 5, '11
From denver co
QUOTE (95CelicaST @ May 5, 2011 - 8:59 AM) *
ya the driver side looks fine, im worried that if i move the bolts over that far its going to crack the edge when i tighten them back down
post May 5, 2011 - 2:39 PM
mgnt232
Joined Mar 16, '09
You prob will get cracks.
I suggest getting some fiberglass resin and mat, just incase. its honestly not hard to work with if u take ur time, and mix it right.
Most all bodykits dont fit. its just the unfortunate reality lol.
get some pics and we'd be able to help you better. but if you have a little crack, it really wont be hard to fix.
I ended up having to cut my front Invader bumper right in half cause it didnt fit right, and filling in the middle. And it was my first time working with fiberglass/bondo.
just get some pics
- 6GC for Life -
>Semper Fi<
1994 Cupra :p 3sgte
1995 Celica ST DD
1969 Chevelle SS
alllll balls. P2 approved!
Lo-Fi Version Time is now: November 26th, 2024 - 9:49 AM
