Help please: WHICH FUSE IS FOR THE BACK WINDOWS ??, convertible back windows |
May 5, 2011 - 3:57 PM |
Enthusiast Joined Jan 18, '08 From Brea, California Currently Offline Reputation: 10 (100%) |
hello, guys, by back windows don't go down anymore...
Does someone know which fuse is it, or is it in the trunk fuse box???? what does it say??? -------------------- Luis
May 6, 2011 - 1:18 AM |
Enthusiast Joined Jun 16, '07 From Vancouver, Canada Currently Offline Reputation: 14 (100%) |
check GAUGE and POWER.
May 6, 2011 - 9:53 AM |
do both the rear windows not work and did you even look for a blown fuse?
May 8, 2011 - 12:17 PM |
do both the rear windows not work and did you even look for a blown fuse? yes both windows don't work, and all the fuses are fine, none of them are burn, a while ago i change the floor carpet myself and i'm thinking i disconnected something, that's is all i can think of. -------------------- Luis
May 11, 2011 - 12:24 AM |
each window has a plug behind the quarter trim.
unless by coincidence that your switch contacts just happen to go bad as your started your project? -------------------- |
May 23, 2011 - 9:52 PM |
Enthusiast Joined Mar 26, '10 From Bronx, Ny, 10466 Currently Offline Reputation: 3 (100%) |
Speaking, of that. When your switch contacts begin to go bad does your windows work perfect sometimes, and then not at all sometimes?
May 23, 2011 - 11:24 PM |
Enthusiast Joined Mar 24, '11 From 704 Currently Offline Reputation: 3 (100%) |
That, the motors, your relays or your fuse could be going bad haha. Do both of them go bad at the same time?
May 24, 2011 - 2:28 AM |
Speaking, of that. When your switch contacts begin to go bad does your windows work perfect sometimes, and then not at all sometimes? If you have to repeatedly try your switches to get your window to go up or down its usually a case of bad contacts. If your windows goes down and up very slowly... its possible your motor is dying. If your windows goes down fine but up slowly it could possibly mean your window tracks are gunked up. -------------------- |
May 27, 2011 - 8:39 PM |
Enthusiast Joined Jul 24, '08 From Canoga Park CA. Currently Offline Reputation: 0 (0%) |
Speaking, of that. When your switch contacts begin to go bad does your windows work perfect sometimes, and then not at all sometimes? If you have to repeatedly try your switches to get your window to go up or down its usually a case of bad contacts. If your windows goes down and up very slowly... its possible your motor is dying. If your windows goes down fine but up slowly it could possibly mean your window tracks are gunked up. I have cleaned my rear quarter window switch 2x in the last 2 years. If the drivers one stops working it is linked to the passenger switch. If you can get it to move a little by keep messaging it you can probably clean it there is a guide here that I used. |
Lo-Fi Version | Time is now: January 10th, 2025 - 5:18 AM |
