> trans fluid dirty / metal shavings ?, how much is normal ?
post May 6, 2011 - 7:55 PM
Culpable04
Joined Apr 17, '06
From New Jersey
I drained my transmission today and found this
as you may be able to see, there are some brownish / bronze shavings floating around, not big enough to be felt by hand, and are not attracted to a magnet.
how concern should I be ?
trans drives fine, there is a little play from standing to get going, this is known as preload on drag racing and I've read that some play is normal, again not sure how much is normal.
I daily drive the car 90 miles a day, no issues.
it used to pop out of 4th gear and used to grind a litttle on 3rd gear, but I adjusted the clutch engagement point and pedal high and it all went away.
let me hear your input.
post May 6, 2011 - 8:39 PM
rust.
post May 6, 2011 - 10:44 PM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
Do a fresh fluid change now and do one not long after and it should be fine.
post May 6, 2011 - 11:22 PM
azn87
Joined Aug 2, '06
From bay area
what kind of oil do u use??
post May 7, 2011 - 12:50 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
QUOTE (lagos @ May 6, 2011 - 6:39 PM) *
rust.
its not rust
that is normal for transmissions, you have all that gear mesh going at high speeds. use regular 80/90 gear oil. i dont see a point in spending crazy money for synthetic oil.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 7, 2011 - 4:09 AM
Johnnyny
Joined Apr 28, '09
From York pa
mmm looks tasty
post May 7, 2011 - 9:54 AM
Culpable04
Joined Apr 17, '06
From New Jersey
I had pennsoil synchromesh,
now I filled it up with mobil 1 75W 90, I had great results with this before so went back to it.
later today I'll report how the trans feels, I just finish refilling it
post May 7, 2011 - 10:30 AM
Bitter
Joined Mar 11, '06
From Way South Chicago
normal powdered metal, lil brass from the synchro's and a lil steel from the gears. how long was that oil in there for?
send it off to blackstone labs and they can give you a good idea of how its doing inside.
This post has been edited by Bitter: May 7, 2011 - 10:30 AM
post May 7, 2011 - 11:23 AM
Culpable04
Joined Apr 17, '06
From New Jersey
it's been in there for around 10K miles ( since Sept last year I think )
before that, the trans was sitting at an engine / trans importer
I'm at work, drove the car here and feels normal, a little smoother, but no big difference on the driving, so I guess I'm in the clear for now.
I also measure the fluid drained to make sure I wasn't running low and I got exactly 4.2 qts out of it, so it's not leaking fluid in any way, which is a good thing.
Lo-Fi Version Time is now: December 4th, 2024 - 8:43 PM
