May 7, 2011 - 3:09 PM
![]() Enthusiast Joined Jul 29, '08 From N. E. Ohio Currently Offline Reputation: 0 (0%) |
There are more than a few known problems with this car (1995 Toyota Celica ST; 1.8L, 7A-FE) that I need to deal with and I intend to but, right now, I need to focus on passing the emissions test. I'm wondering if some of these other issues may, directly or indirectly, be the cause.
I'm failing the emissions check test due high NOx: 2624.4 with acceptable being around 1072.
It did drop each test and, by the third, it is significantly lower (around 1500) but still not low enough (1072) to pass. I guess I'll have to replace the catalytic convertor next but is there anything else that could bring it down (almost 500) I might try first ? A known problem I have is oil leaking into the spark plug wells and I think some might be getting burned. Regardless, I intend to replace the valve cover gaskets, then oil change and filter, new plugs and wires, etc. but, in the meantime.. Would this (oil burning) problem increase NOx readings? Would this (oil burning) problem cause the catalytic convertor to fail (which, in turn, would increase NOx readings)? Thanks |
ActionClaw Still not passing emissions check May 7, 2011 - 3:09 PM
D-Man Remove and clean both O2 sensors. Should have lots... May 7, 2011 - 8:07 PM
ActionClaw QUOTE (D-Man @ May 7, 2011 - 8... May 8, 2011 - 12:07 AM
D-Man QUOTE (ActionClaw @ May 8, 2011 - 12... May 8, 2011 - 11:34 AM
Bitter check ignition timing to ensure its spot on at 10d... May 8, 2011 - 10:35 AM
bmj67 I didnt see a tune up on your list of stuff you di... May 8, 2011 - 10:46 AM
al94st Sounds like you need some ammonia injection into y... May 8, 2011 - 12:17 PM![]() ![]() |
| Lo-Fi Version | Time is now: January 12th, 2026 - 4:52 AM |
