> new clutch
post May 8, 2011 - 7:44 PM
yaj204
Joined Nov 29, '07
From california, marysville
clutch went out... i was just wondering whats the best or better brand out their for the 5sfe?
post May 8, 2011 - 9:40 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
If you're planning to keep the motor relatively stock, I'd go with an OEM toyota clutch if you can afford it.
If not I'd get an exdy OEM replacement, which is slightly cheaper than an OEM.
I just put a new OEM clutch in my car.
My Celica!
post May 9, 2011 - 11:01 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
^^^ cant argue with this. if you want a slightly upgraded clutch, i suggest Southbend clutch. they are fantastic and have incredible customer support if you need it.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 9, 2011 - 11:39 AM
malecrod
Joined May 30, '05
From MN
As said above. If car is not modified and money is not an issue, go with OEM. Clutch labor is not cheap and if u do it yourself its time consuming. Otherwise, I had some luck with exedy and ACT.
3sgteing.
..burns twice as bright, lasts half as long.
"The weight of the world is love. Under the burden of solitude, under the burden of dissatisfaction."
-Allen Ginsberg-
post May 9, 2011 - 11:50 AM
mkernz22
Joined May 10, '10
From MA
It only takes about a day to do the clutch (if you know what you're doing) haha but to have a shop do it, it costs quite a bitttt
post May 12, 2011 - 10:57 PM
yaj204
Joined Nov 29, '07
i'm just doing it myself... the tranny's out already....its not the first time..... but thanks for the info
Lo-Fi Version Time is now: December 11th, 2024 - 5:08 PM
