> Removing drive shaft seal, I'm covered in oil and need a quick reply if possible! :-)
post May 10, 2011 - 8:09 PM
S8S8
Joined May 9, '09
From Brisbane, Australia
What's the best way to get the drive shaft seal out? I'm talking about the one in the gearbox that faces towards the timing belt end of the engne.
I've removed the axle and can stick my fingers into the gearbox, but I just can't pop the rubber seal out.
Any ideas? I assume there's some sort of trick to it.
Thanks.
post May 11, 2011 - 5:10 PM
S8S8
Joined May 9, '09
Anyone? I've searched this forum and others and just can't find the answer.
post May 11, 2011 - 9:09 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
takes more than fingers, you need a seal remover and have to be delicate.
post May 12, 2011 - 12:09 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
use a long screwdriver or prybar and just pry it out
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 12, 2011 - 12:25 AM
S8S8
Joined May 9, '09
Thanks for the replies.
I tried the screwdriver method on my spare gearbox and it worked fine with a bit of force, but the one in the car just won't budge.
I also tried using a piece of solid metal tube as a lever, then bashed it with a mallet and the seal still won't move at all.
Another forum gave me this reply which I think I'll try next:
Soak it in WD 40 Overnight, Then got some cold spray and spray the seal and imediatly remove it.
If this doesnt work repeat, but heat the outside of the gear box up slightly with some lp gas or oxy.
If this dont work you may have more serious problems...
post May 12, 2011 - 2:54 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
well if youre gonna replace them just get channel lock pliers and manhandle those things out. just dont scratch the inner bore
post May 12, 2011 - 7:08 AM
Needles
Joined Nov 18, '10
From montreal
i wonder what kind of sealant they used to lock ur seal like that lol
This post has been edited by Needles: May 12, 2011 - 7:09 AM
post May 12, 2011 - 7:33 AM
czwalga
Joined Sep 27, '10
From pittsburgh
I used a screw driver and sledge, but that was with it out of the car. If its in the car go to the autoparts store and rent a slide hammer. It will come out easy. Get the hook on the inside of the seal and pound it out.
You couldn't have pounded on them too hard, otherwise they would have broken. If they are in there tough you can just destroy the seal. All it is is thin metal/rubber/tightly wound spring. There's no sealant or anything.
This post has been edited by czwalga: May 12, 2011 - 7:35 AM
-93 Rx7, Turbo 6.1L v8, 725rwhp/760rwtq
-95 Celica GT Rally Car - 3sge/AWD
-10 F150
Always buying stock wheels... PM me if interested in selling.
post May 12, 2011 - 1:15 PM
jlive
Joined Sep 6, '10
From Lancaster, CA
I used a come-a-long hook. Rubber end of course as to not damage the tranny. Then I stood on the side of the car and yanked on the strap until it popped out.
If you pry it out be careful not to scratch or gouge the tranny where the seal goes.
post May 12, 2011 - 2:28 PM
Hanyo
Joined Aug 16, '03
From Bay area
post May 12, 2011 - 10:49 PM
soulshadow
Joined Apr 18, '05
From Lincoln, Ar
QUOTE (Hanyo @ May 12, 2011 - 2:28 PM) *
Hands down for this one, Took less than a sec to get both sides out!
post May 13, 2011 - 4:50 AM
S8S8
Joined May 9, '09
Please welcome the latest addition to my tool shed!
Sometimes you just can't beat the right tool for the job. After stuffing around for hours with screwdrivers and whatever, it took about 30 seconds to pop the seal out with the proper tool.
The seal is now replaced and there are no leaks. Not yet anyway...
Lo-Fi Version Time is now: November 23rd, 2024 - 4:00 PM
