> 5S-FE --> 3S-GTE
post May 15, 2011 - 1:45 AM
OmegaV4
Joined Jun 4, '09
Long time reader, first time poster.
The situation:
Got a 1995 GT-S(Canada) with a 5S-FE engine in it and was looking to swap it out for a 3S-GTE(ST205)
The question:
What would need to be changed/added/purchased in order to do this smoothly? I've read the sticky on the feasible swaps, and I took note to the fact that it is a drop in swap, however, in discussing with a friend of mine, he told me that because it's a JDM motor going into a North American car, the steering may need to be modified/changed. Is this true?
post May 15, 2011 - 6:16 AM
CoreyST
Joined Feb 25, '11
From Delaware
As far as I know steering doesn't need to be changed, and if you buy a front clip you will have everything you will need to swap over.
post May 16, 2011 - 3:21 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
Search for swaps and progress threads, most people document what they had to do to get things running.
Mike W
269awhp / 273ft-lbs
post May 26, 2011 - 9:21 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
you dont have to change a thing related to the steering.
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post May 26, 2011 - 9:28 AM
PhoenixTech
Joined Dec 3, '08
From Summerville, SC
It's pretty straight forward to be honest. the 5S and 3S are both S-series motors, therefor, are extremely easy to swap out for one another. You can use your existing motor mounts, transmission, shift linkage, axles, A/C compressor, A/C lines, P/S lines. You'll need your harness converted to work in the USDM Chassis, (PM me for details on that) but aside from that, if you know what a wrench is, this is a very feasible swap for you.
and smack your friend for the "steering changes" comment.
www.tweakdperformance.com
sales@tweakdperformance.com
post May 28, 2011 - 12:33 PM
brenton1919
Joined Feb 28, '11
QUOTE (OmegaV4 @ May 15, 2011 - 2:45 AM) *
The situation:
The question:
nothin needs to be change it is a drop in swap the only thing you have to worry about is the wireharness
post Jun 7, 2011 - 10:38 AM
LAcelica94St
Joined Jan 12, '10
From South Gate, Ca
I'm almost I a similar situation, I'm in a Position with the swap. What about things like the radiator, or brake systems and things like that? And does a mr2 wire harness work on the celica???
post Jun 7, 2011 - 11:28 AM
You guys need to read this:
http://www.6gc.net/forums/index.php?showtopic=28825
As for the mr2 engine/harness... you are going to make your swap harder by going with these. The wiring harness will be completely different and need to be sent out to someone to be rewired. Also there are alot of small differences in the placement of things like the alternator that will make your swap difficult.
Your best bet for success is to start out with a GT car, and use an st205 3sgte. This will be the easiest swap, with the least wiring and headaches.
post Jun 7, 2011 - 12:10 PM
LAcelica94St
Joined Jan 12, '10
From South Gate, Ca
QUOTE (lagos @ Jun 7, 2011 - 12:28 PM) *
Thanks for the link, very informative. So when in call looking for a font clip,
post Jun 9, 2011 - 5:12 PM
LAcelica94St
Joined Jan 12, '10
From South Gate, Ca
do i need to change all the little things for this swap, like fuel pump, or alternator? kindasad.gif
post Jun 9, 2011 - 5:26 PM
Lone_Wolf
Joined Apr 22, '09
From Work
QUOTE (LAcelica94St @ Jun 9, 2011 - 6:12 PM) *
http://www.6gc.net/forums/index.php?showtopic=27939
http://www.6gc.net/forums/index.php?showtopic=77843
This post has been edited by Lone_Wolf: Jun 9, 2011 - 5:27 PM
**If you can read this you are too close**
Lo-Fi Version Time is now: November 27th, 2024 - 4:35 PM
