Enthusiast ![]() Joined Jun 4, '10 From Jax Beach, FL Currently Offline Reputation: 0 (0%) ![]() |
My gears have been shifting a little hard so I thought I would finally get around to changing my tranny fluid. I open the plug....and a drop comes out..ha I thought there was no tranny fluid in there then I realized that was the fill plug. So i found the drain at the bottom, but I cant get my airgun in there and I think I might have stripped it.
This post has been edited by m2736185: May 21, 2011 - 6:53 PM |
ok
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 18, '06 From Calgary, Canada Currently Offline Reputation: 37 (100%) ![]() |
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 8, '03 From Lancaster CA Currently Offline Reputation: 6 (100%) ![]() |
its a 24MM nut. use a standard 24MM 1/2 drive socket and remove it. never use air tools on oil plugs
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) ![]() |
its a 24MM nut. use a standard 24MM 1/2 drive socket and remove it. never use air tools on oil plugs x2 socket socket socket. i tried to use a wrench and damn near stripped it -------------------- |
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Oct 20, '08 From Seattle, WA Currently Offline Reputation: 5 (100%) ![]() |
Don't over torque it when you put the bolt back on. Chances are the shop or wherever you had it done last over torqued the **** out of it, happened to mine first time I changed my tranny fluid and made it a pain to get off (nearly stripped mine). I'm not 100% but iirc that particular drain bolt is about 50 ft/lbs.
-------------------- 2006 BMW 330i - 6 Speed - Dinan Stage 1
2014 Toyota Rav4 XLE |
Lo-Fi Version | Time is now: February 17th, 2025 - 6:49 AM |
