> stupid leak, kks
post May 22, 2011 - 6:34 PM
Needles
Joined Nov 18, '10
From montreal
i change my fuel filter and now its leaking from the bottom, there no sign of damage and i have lock it hard enough for sure 3 time, and the leak stay, any suggestion, i have change to walbro 255
This post has been edited by Needles: May 22, 2011 - 6:35 PM
post May 22, 2011 - 7:11 PM
Needles
Joined Nov 18, '10
From montreal
maybe my fuel rail limit, how can i check my fuel rail setup ?
post May 22, 2011 - 10:17 PM
senick
Joined Mar 29, '11
From Bloomington, IN
Well, you may have over-torqued the filter. I think the bolt on the bottom is only supposed to be 22 ft-lbs, and it's possible that if it's too tight that might cause a leak. Or you may have cross threaded the filter and caused it to leak. I'd just take it off and inspect the threads then carefully put it back on, and snugly tighten everything by hand and see what happens. Hopefully it's just something minor like that.
Lo-Fi Version Time is now: November 23rd, 2024 - 11:58 AM
