> Painting front end, Pics as I go.
post May 26, 2011 - 10:06 AM
purplegt4
Joined Feb 7, '03
From Northern Virginia
Painting my new front end
5/25/11
First time using my new best friend. This was SO MUCH faster than by hand. Took like 20 minutes!
No before, but here's the after.
post May 27, 2011 - 10:26 AM
purplegt4
Joined Feb 7, '03
sanding the fenders
As she sits now.
post May 27, 2011 - 1:17 PM
chacha
Joined Dec 29, '05
From So-Cal
GREAT job, i wish i had the tools and confidence you got to do it, other wise i do it myself too.
post May 27, 2011 - 2:21 PM
purplegt4
Joined Feb 7, '03
thanks! tools have been piling up over the years, just need some experience now.
post May 27, 2011 - 2:24 PM
KAOS
Joined Apr 18, '06
From Calgary, Canada
QUOTE (purplegt4 @ May 27, 2011 - 1:21 PM) *
I have to do this at some point this summer too... thank you for the POST; I'll be sure to follow along and compare notes. wink.gif
post May 27, 2011 - 2:28 PM
CelicaHD2
Joined Aug 15, '10
From UK
Looks like you are getting on nicely...for some tips and ideas on how to blend the paint and show others what is involved, can I recommend looking for videos by a guy called JIMMO4LIFE on Youtube.
He has got some good videos on there with text subtitles to explain as he goes.
post May 27, 2011 - 2:32 PM
purplegt4
Joined Feb 7, '03
QUOTE (KAOS @ May 27, 2011 - 2:24 PM) *
you have a two tone scheme goin on right now too? i'll make sure to take more pics.
QUOTE (CelicaHD2 @ May 27, 2011 - 2:28 PM) *
Thanks for the link! I've never done any blending, and I really just didn't want the front to be silver anymore. I know I'll have to blend some because it's definitely going to be noticeable.
post May 27, 2011 - 2:36 PM
KAOS
Joined Apr 18, '06
OH!
I didn't know you were all in for a two-tone paint job. No, I just need to fit my C-One knock off, then sand down, & prime the rest of my car.
post May 27, 2011 - 2:52 PM
purplegt4
Joined Feb 7, '03
no, no two-tone. trying to steer clear from that mess.
post May 27, 2011 - 2:53 PM
KAOS
Joined Apr 18, '06
QUOTE (purplegt4 @ May 27, 2011 - 1:52 PM) *
Oh sh!t; hahaha i just re-read your original post. Yes I have a rolling crayola box of a mess right now... tongue.gif
post May 27, 2011 - 9:39 PM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
lookin good....atleast you have a decent base to paint on...mine i had/still have to finish removing this cheap ass paint that wouldnt come off easy unless i used a scraper/wire wheel on a drill...(hood both fenders and bumper was like this) im on the filling the deeper scratches the wire wheel left behind with spot putty and removing dents and stuff then onto primer and paint.....i wanna punch whoever painted this in the throat hole!
lookin good....atleast you have a decent base to paint on...mine i had/still have to finish removing this cheap ass paint that wouldnt come off easy unless i used a scraper/wire wheel on a drill...(hood both fenders and bumper was like this) im on the filling the deeper scratches the wire wheel left behind with spot putty and removing dents stuff, then onto primer and paint.....i wanna punch whoever painted this in the throat hole!
post May 27, 2011 - 10:14 PM
azian_advanced
Joined Apr 18, '05
From Calgary
nice sander, i just hope you have something to do the curves and corners on the bumper, or else you'll be using a lot of elbow grease.. haha and i'll leave it at that. biggrin.gif looking forward to see the progress on this job.
post May 30, 2011 - 1:11 AM
QUOTE (azian_advanced @ May 27, 2011 - 10:14 PM) *
i have a trick for that...
post May 30, 2011 - 9:46 AM
KAOS
Joined Apr 18, '06
QUOTE (njccmd2002 @ May 30, 2011 - 12:11 AM) *
Norberto - something you'd like to share with the rest of the class? tongue.gif
post May 31, 2011 - 11:07 AM
purplegt4
Joined Feb 7, '03
All sanded parts getting ready for first shot of primer
Fenders match after some plier/hammer work
Stopped at the auto body shop for some supplies. Body filler, base/thinner (1:1), clear/hardener (4:1), primer/thinner (1:1) I have two of most because of the leftovers I had from previous projects.
The ding and scratches from the sander. Note to self, never use such a super low grit (80) just to take off paint.
Poorly done job of ding fixing and sanding. I could still see after the first layer of primer.
Go away rain. I have to spray.
Rain went away so I sprayed. Just a couple coats for 320 grit sanding to see my imperfections.
Primered pics
5/30/11
320 grit sanding ready for a wash prior to another layer of primer
I still have to fix/fill/sand some parts before another coat of primer then 600/800 grit sanding prior to base coat.
post May 31, 2011 - 8:16 PM
Stambo
Joined Apr 23, '08
From Muskego,Wi
i did the same thing as you, the body guy whose painting mine told me to take the paint off with 80 than i did another sanding with 180 grit on the hood. Brought it all the way down to bare metal. The worst part was sanding the vents..... Big pita!
Looks like it is coming along tho!
2nd Gen 3s-gte.... It lives!
97celiman
post Jun 6, 2011 - 11:13 AM
purplegt4
Joined Feb 7, '03
ye olde makeshift cover
no time for you.
sanded front bumper
the cover, next time i might seal it as the overspray went over the neighborhood (sorry!)
8k9'd
fenders, too.
put all together! (front bumper is for sale)
post Jun 6, 2011 - 11:35 PM
i have the same compressor, but the sander keeps spitting water, how did u solve it?
post Jun 7, 2011 - 4:28 AM
CelicaHD2
Joined Aug 15, '10
From UK
QUOTE (njccmd2002 @ Jun 7, 2011 - 5:35 AM) *
Usually you should have an air regulator/air filter unit which helps collects moisture in the airline. Plus you could also get an inline moisture trap that fits at the end of your pipeline...just before your air tool to collect the last bit of moisture.
If you look at the picture of the spray gun hanging up in his booth...the green unit the last bit of moisture control.
This post has been edited by CelicaHD2: Jun 7, 2011 - 4:29 AM
post Jun 7, 2011 - 10:35 AM
purplegt4
Joined Feb 7, '03
QUOTE (CelicaHD2 @ Jun 7, 2011 - 4:28 AM) *
Happened to me, I just slowed the sander down.
Lo-Fi Version Time is now: February 17th, 2025 - 2:07 AM
