> new wheels
post May 26, 2011 - 11:32 AM
SoundSlut_dotcom
Joined Feb 16, '03
Ok so I'm looking at a 18x8 +35 , 225 35 18 tires , will these fit proper? I am also on airbags.. anyone have this setup? W or w out bags? And problems ?? Please need feedback asap!
post May 26, 2011 - 1:17 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
I have 225/40/18 on an 18x8 +35 and it rubs the slightest bit on the rear fenders by less than 1/8th of an inch over large bumps or with two people in the back, and thats lowered on tien s-techs and blown stock struts.
I don't think it will rub once the struts are changed, which I will be doing tonight.
My Celica!
post May 27, 2011 - 11:06 AM
SoundSlut_dotcom
Joined Feb 16, '03
QUOTE (jordisonjr @ May 26, 2011 - 11:17 AM) *
Thanks.. how do u like the +35 ? Satisfied w the look ?
post May 27, 2011 - 4:41 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
225/35/18 with max camber bolts you should be fine
post May 27, 2011 - 4:53 PM
pipes
Joined Apr 23, '08
From boston MA
225/40/18 x 8.5 cant remember the offset and im quite low no rub issues
post May 27, 2011 - 7:04 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (SoundSlut_dotcom @ May 27, 2011 - 12:06 PM) *
The fronts sit basically perfect, the rears could come out a tiny bit more, but you would need to roll the fenders forsure.
Its probably only a couple mm away from flush.
It rubs on about the first 1/8" of the lip so that kind of gives you and idea. But I'm pretty satisfied with it.
My Celica!
Lo-Fi Version Time is now: January 15th, 2025 - 2:50 PM
