The white rescued Celica. (1994 ST204) Pictures galore., Suspension re-do time! |
Mar 15, 2013 - 12:07 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Woohoo! They accepted the offer of $900 on a brand new set of D2 Racing RS purple and black coilovers haha. $900 shipped. Now I'm broke >.> looks like ramen and the dollar menu for the next two weeks lolol
-------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Mar 25, 2013 - 8:14 PM |
Discovered that my D2 RS's are rear camber adjustable. The pillowball mounts have top adjustments front and rear! No one else lists this for the Celica from what I've seen. So pumped.
Also, test fit of wheels. Tires are 205/55/16 and way too big lol. Looking at either 195/45 or 175/50 Yokohama S.Drive tires. Going poke, camber, and slammed lol. Wheels are getting the centers powdercoated white and the lips will be polished. This post has been edited by RabidTRD: Mar 25, 2013 - 8:15 PM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Mar 26, 2013 - 6:31 AM |
oh yeah.... much less tire needed haha
-------------------- 1995 GT::::Diffusing the Situation エキサイティングカーレーシングチーム! march 2010 COTM : 6GC feature 2014 : january 2015-2016-2018 COTM |
Apr 17, 2013 - 10:28 PM |
Well the coilovers are on. ****ing annoyed. Has anyone ever had a completely **** experience with Coilovers before? The product it's self seems top notch, but the feel I get is ****ing horrible. So bad that I'm actually really tempted to go back to the Koni Yellow's with Eibach's.
So dropping the car another inch somehow ****ed the toe in / toe out on both front and back bad enough to make it feel like I'm driving a squishy old pig. The front tires are like \ / and the rear sits like / \ . I don't know if this is the reason the car feels really off or if it's something to do with the coilover, but so far, I'm extremely annoyed. My tires are making a stupid whurring noise on the right side too, possibly because of the alignment being so bad, but from 0 - 15mph it's almost unbearable. These pillow ball mounts really translate noise very well. So anyway, on to the goodies: Spring rates of the rear Spring rates of the front Before setting it down After Worked late into the night Rear top mount has lots of options for camber as well as the bottom of the strut. You have to modify the body to use these top adjustments though. This was my position most of the night. Stupid rusted bolts Came back to it in the morning. Got 3 out of the 4 done and started again once I woke up. My girlfriend Sara helped too lol Old, but still good. Lower. Can't go lower than this until I modify my exhaust height underneath. It's an inch from the ground at this point. Once I get the new wheels on, I'll see about the exhaust height. Also, the rear sway bar is almost at the frame. It's swung up so far to meet the new mounts for the coils. Has anyone figured out a solution for this? Longer links? or does it run fine like this? This post has been edited by RabidTRD: Apr 17, 2013 - 10:33 PM -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 18, 2013 - 8:42 PM |
Well I'm a ****ing idiot. The dual core radiator means twice the coolant. My car isn't designed to move that much coolant and the fans can keep that much cool, so the car is overheating. I should have known the instant when I put it in and the pressure went high enough to keep leaking past my hoses. The top of the radiator tanks is even starting to bow. So **** aftermarket radiators with dual cores. Going back to a single core factory one since it worked fine. Only issue was the stupid thing leaked. Never overheated. Now that I've go more powerful and faster fans, it should work great. The radiator support got so hot today that I couldn't even touch it. This is on a 75 degree day too.
So now I need to figure out where I'm going to get $150 to pay for it Got two of the four rims sand blasted, so they're almost ready... Tires are still suffering from bad toe out. I wish making mistakes in the car works wasn't so expensive. Here's a question though: which way are the radiator fans suppose to blow? Towards the radiator right? Not sucking air through towards the engine? Is it possible to wire hem backwards? Because I thought they only had ground and positive. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 18, 2013 - 9:06 PM |
Enthusiast Joined Jan 26, '09 From Los Angeles Currently Offline Reputation: 1 (100%) |
Yeah..mistakes can be very expensive.
As far as your fans..they should be PULLING air from the front of the car through your radiator and "onto" your engine. The important part is that it pulls air from the front. having them blow the other way would push the hot under hood temp air through your radiator.. -------------------- |
Apr 18, 2013 - 10:28 PM |
Yeah..mistakes can be very expensive. As far as your fans..they should be PULLING air from the front of the car through your radiator and "onto" your engine. The important part is that it pulls air from the front. having them blow the other way would push the hot under hood temp air through your radiator.. As far as I know, they're pushing air towards the front. SO, I've got them wired backwards?! ****ing hell if that's the only reason I'm going to **** a brick. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 18, 2013 - 10:41 PM |
What I did when I wired it was to wire the blue wire on the new fans to the blue wire on the factory plug. Black to black as well. Is that the wrong way? This would make sense as the fans have always made a noise like they're blowing against the radiator. I always just thought it was a faster moving fan and that was why.... >.>
Is this why no one else has had this issue with dual core radiators? lol ...I feel so stupid. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Apr 19, 2013 - 1:09 PM |
Enthusiast Joined Apr 12, '13 From Bulgaria Currently Offline Reputation: 53 (100%) |
Nice looking Celica, dude. A lot of work put into it.
May 10, 2013 - 2:04 AM |
Whelp fans are have been wired the correct way for a few weeks now without any issues. No more overheating.
I've also been working on my wheels a bit with Sara's help. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
May 10, 2013 - 2:22 AM |
Enthusiast Joined Nov 29, '10 From Lake Havasu City, AZ Currently Offline Reputation: 31 (100%) |
How do you feel about the D2's now that they been on for a bit??
-------------------- 6gcHeroes:808hectortimmybatmandiegotigamak |
May 10, 2013 - 7:28 AM |
are those wheels faux 2 piece??
May 10, 2013 - 11:29 AM |
How do you feel about the D2's now that they been on for a bit?? Now that I have an alignment and they're settled, I LOVE them. I dig into corners like never before, and that's on WINTER tires! Half way on the strut adjustment is almost perfect for daily use. It's a bit bumpy, so I may back it off to 14 instead of 18, but it's freaking great in the bends. are those wheels faux 2 piece?? Yup haha. Leaving the wheel bolts out. I like the look of it open. The theme will be a polished aluminum lip (I don't like chrome) and a powder coated white center. Looking for a center cap that I can polish (aluminum) too. I may order another set of emblems from Smkr3w and use them on the center caps. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
May 10, 2013 - 11:48 AM |
Also went to a meet on Sunday:
More pictures here: https://www.facebook.com/media/set/?set=a.1...3798&type=1 -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 23, 2013 - 12:49 PM |
Jun 24, 2013 - 4:16 AM |
'bout time! haha very nice
Jun 25, 2013 - 2:47 PM |
This is how they're all going to look when they're done.
The painted one is what I started with. This is a great example of the process lol. Closest one is the finished, then the non-polished, then the resurfaced lip/still needs some paint removal, and lastly the painted one. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jul 20, 2013 - 1:43 AM |
So my birthday is coming up and a large box arrived at my girlfriends from Japan... She had been asking me what I wanted for the Celica and I told her that I would love to have a rear window spoiler/sunshade... it's about that length... 0.0 Here's to hoping. lol
Jul 20, 2013 - 1:01 PM |
Nope, it's a rear spoiler. Close enough.
Jul 24, 2013 - 11:05 PM |
And racecar:
The driveway makes the rear pass gap look huge. I'll put up some pics after fri when I finalize the fitment. Right now it rubs like nuts (still haven't rolled the fenders lol) and I need some front and rear camber. Going to pull the front fenders a tad to get a better fitment too. Possibly going lower soon, but I have to adjust the exhaust up a bit. The Ultra Quiet resonator is scraping on stuffs. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Lo-Fi Version | Time is now: November 23rd, 2024 - 2:17 PM |
