wheel rub, pics posted |
Jun 5, 2011 - 5:06 AM |
Enthusiast Joined Dec 8, '05 From torrance/carson, ca Currently Offline Reputation: 11 (100%) |
my car is lowered about an inch on 215/45/17 tires. and i just got some spacers to make my wheels flush with the fenders. but now i hear a little wheel rub at times. what kinda damage will that do? and when i say 'a little' wheel rub, i mean a split second on hard turns or dips if i'm not going slower than usual. will post photos when i get a chance...
This post has been edited by j0e_p3t: Jun 15, 2011 - 1:33 PM -------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jun 5, 2011 - 12:20 PM |
Enthusiast Joined Dec 26, '09 From Albuquerque, NM Currently Offline Reputation: 19 (100%) |
It'll put wear spots on your tires.
June '12 COTM '95 AT200 |
Jun 5, 2011 - 10:35 PM |
Enthusiast Joined Jan 20, '09 From Winnipeg Currently Offline Reputation: 5 (100%) |
What are you rubbing on the metal?
In the rear, if you're only rubbing on large dips, just go in there with a rubber mallet (or fender roller if you can get one, which is the proper way to do it) and you can bend up the lip just enough so that it doesn't rub. Thats what I did and it solved my problems. Not sure what you can do about the fronts though if you are rubbing the fenders, because they come rolled from the factory. If your rubbing on the front plastics, you could always cut small sections out of the plastics where you rub if it rubs a lot, but that will allow dirt in your engine bay. If it doesn't rub a lot on the plastics, only sometimes, its not a huge deal. -------------------- -Protection mode, For when your amp tries to blow its load. 1995 Toyota Celica GTS - Daily Driver 1999 Chevy Cavalier - Winter Beater 1994 Honda Civic CX Hatchback - Dead My Celica! |
Jun 15, 2011 - 1:30 PM |
i'll try the fender roller in the rear. i might even end up selling these and buying thinner spacers...
couple quick camera phone pics This post has been edited by j0e_p3t: Jun 15, 2011 - 1:31 PM -------------------- ss-iii splitters and 404 skirts are on. which means i need to update my sig. |
Jun 15, 2011 - 3:20 PM |
what is your offset now with the spacers fitted? I would of preferred your other rims instead. Hard to see black rims at night.
Jun 15, 2011 - 7:49 PM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
your suspension is too soft......
-------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 15, 2011 - 8:28 PM |
Moar camber.
Lo-Fi Version | Time is now: January 9th, 2025 - 10:06 PM |
