NEED HELP: CAR IDLEING WEIRD !!!!, asdfa |
Jun 6, 2011 - 1:01 PM |
Enthusiast Joined Jun 5, '08 From Portland, Oregon Currently Offline Reputation: 6 (100%) |
When it idles it goes to like 100-200 rpm and when i hit the ac on it will go up to like 900 rpm
sometimes if i let idle for awhile it will go to 100-200 and start studerring and clicking. Vacuum leak? i have no idea, let me know what u guys think, ill try to get a video This post has been edited by JDUB: Jun 6, 2011 - 9:08 PM |
Jun 6, 2011 - 4:51 PM |
dude i cant help you without hearing it, thats way too vauge of a description
Jun 6, 2011 - 5:41 PM |
Transmission whine. Your car is fine.
Or your transmission is about to grenade... BOOM who knows, because you posted a vague description and no audio clip. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Jun 22, 2011 - 6:39 PM |
Enthusiast Joined Apr 22, '11 From Massachusetts Currently Offline Reputation: 0 (0%) |
You need to adjust your idler, 5sfe should idle at 700-900RPMs. You can adjust it by tweaking your cable that is attached to the throttle body. The reason why it's studdering is because it's about to stall out. Cars can't idle that low not even a ****ing prius haha.
Second, the reason why your idle goes up when you turn the A/C on is because the A/C compressor is run of your drive belts. It uses engine power to run the A/C, so if there is a larger load on the engine, it will increase the RPMs to compensated. In other words it uses up all the Horsepower when you idle so it increases the idle to maintain that same range of Horsepower make sense? This is why races shut their A/C's off because it uses up some Horsepower. |
Jun 23, 2011 - 12:39 AM |
Enthusiast Joined May 9, '11 From Manila, Philippines Currently Offline Reputation: 0 (0%) |
could be your iscv, idle speed control valve.
get a good thorough throttle cleaning, include the iscv on the cleaning. hth |
Jun 23, 2011 - 1:28 AM |
Enthusiast Joined Jan 16, '09 From Cyprus Currently Offline Reputation: 10 (100%) |
I have the similar problem so after a BIG search and many hours in services the reasons for this can be:
-some of the fuel system sensors is dead (4 of them) -need to clean the throttle body very nice! -vacum leak good luck -------------------- |
Jun 23, 2011 - 4:28 AM |
thanks guys! hey cyprus i have the same muffler as you, the people who welding it up put mine kind cricked and pointed downwards, piss me off
Jun 24, 2011 - 1:24 AM |
thanks guys! hey cyprus i have the same muffler as you, the people who welding it up put mine kind cricked and pointed downwards, piss me off ...my is also a little downwards mate HAHAHAHA best mufflet that i ever had cheers -------------------- |
Jun 30, 2011 - 4:00 PM |
clean out your throttle body and IAC valve really well(the iac valvle is under the throttle body....) its best to take it off the engine and completely apart to do this.
Lo-Fi Version | Time is now: November 22nd, 2024 - 3:46 PM |
