meesed up my speedometer |
Nov 7, 2006 - 7:07 PM |
Enthusiast Joined Aug 20, '06 From Kissimmee Currently Offline Reputation: 0 (50%) |
was trying to connect my indiglow kit thingy and now no lights and my arrows dont move
Nov 7, 2006 - 7:11 PM |
Enthusiast Joined Jun 30, '05 From Chattanooga, TN Currently Offline Reputation: 5 (100%) |
check your fuses, you may have grounded the cluster when you put it back in, also make sure you put all your plugs back in the cluster, i know it sounds obvious, but somethings we forget the obvious things
Nov 7, 2006 - 9:41 PM |
Enthusiast Joined Jun 14, '05 Currently Offline Reputation: 1 (100%) |
did you put the needle the same way/location that you took it out?
Yes, it could be an obvious problem. Try taking it out and connecting everything back |
Nov 7, 2006 - 11:09 PM |
Enthusiast Joined Jan 28, '05 From Redondo Beach, CA Currently Offline Reputation: 86 (100%) |
what did you use to put it on, too thick of tape wont let the needles move freely, rubber cement is the best to use to adhere the overlays, nice thin layer will do
Nov 7, 2006 - 11:33 PM |
Enthusiast Joined Jan 25, '06 From MN Currently Offline Reputation: 19 (100%) |
Did you play with the needles when you took your cluster out ??
-------------------- "To Protect And To Serve The Wealthy" -POLICE
Nov 7, 2006 - 11:35 PM |
no i was very careful not to touch the needles
Nov 8, 2006 - 2:19 PM |
i could rip my needles out and the lights would still work... im still thinking its an electrical problem and i would check my fuses. check the back of the cluster to make sure you didnt damage part of that flimsy electrical board putting it in, and make sure you plugged everything back in, did you tap into the dimmer switch for power? when you say the lights dont work, do you mean the gauge cluster lights or the indiglo gauge lights?
This post has been edited by Stu37363: Nov 8, 2006 - 2:21 PM |
Nov 8, 2006 - 10:48 PM |
well i fixxed the problem but i went glue crazy and put to much glue and some of it leaked onto the temp needle and gas needle so now i need to buy new cluster and new guages.....:-\
Nov 9, 2006 - 12:10 AM |
next time use spray on adhesive and just spray it on the back of the indiglo gauges
Dec 7, 2006 - 5:00 PM |
Enthusiast Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
installing these suckers are harder than you think...at most cases, you will have to take out the needles and put the gauges in then place back the needles in the right way...mines are on an average 10MPH slower on the gauge...ill fix it when i find those stand up speed radar detector and plug it in...
Jun 6, 2011 - 9:59 AM |
Enthusiast Joined Jun 6, '11 From bulldog1 Currently Offline Reputation: 0 (0%) |
A dab of 3M super weather strip adhesive applied on the tip of a K bob skew is what i used. Gauges love to flex but a little dab on either side of the needles, carefull NOT to glue them worked like a champ. (under the glo gauge and original face)
Jun 6, 2011 - 10:06 AM |
A dab of 3M super weather strip adhesive applied on the tip of a K bob skew is what i used. Gauges love to flex but a little dab on either side of the needles, carefull NOT to glue them worked like a champ. (under the glo gauge and original face) It makes it easier if you pull straight out any stop pins before trying to install and work your way from longest to shortest needles. Then reinsert pins, You may have to add , or camfer holes first so triple check first then when you are positive you can't screw it up, check once more before you start to make a longshoreman blush !!!!
next time use spray on adhesive and just spray it on the back of the indiglo gauges Spray on adhesive doesn't give you much room for error.Once it's set your done. |
Lo-Fi Version | Time is now: January 9th, 2025 - 1:15 PM |
