> 94 Celica GT : rear wheels locked up on me
post Jun 14, 2011 - 1:00 AM
celi_booster
Joined Mar 26, '11
From Wisconsin
Hey guys, this might be a dumb question but how do we check our cars if our rear wheels are locked up? My rear wheels are locked up after letting it sit in the garage for too long with the e-brake up. While jacking up my car and putting it in neutral, the front spins freely but the rear wheels are locked up. This is my first time, where should I start looking for first?
post Jun 14, 2011 - 10:19 AM
KAOS
Joined Apr 18, '06
From Calgary, Canada
This happened to me once - not sure where you are in this world, but after sitting for so long in the elements, my e-brake had formed a bond with the inside of the rotor. I had to do some serious banging with a hammer to try and loosen them off. You could also try removing the rotor (mind you, I'm assuming you have disk brakes on all 4 wheels - you haven't really given any details), and that process should loosen the grip that the e-brake has to the rotor surface.
post Jun 28, 2011 - 10:32 PM
celi_booster
Joined Mar 26, '11
From Wisconsin
QUOTE (KAOS @ Jun 14, 2011 - 11:19 AM) *
Thanks Kaos. Took your advice and its working again. Yeah, I have disk brakes on all 4 wheels.
post Jun 29, 2011 - 10:44 AM
Neon90424
Joined Jan 19, '11
when my ford escape came in the container the rear wheels were locked up only the right one though...put it in 4wd and after dragging 1 meter it moved...we also beat the **** out of it
post Jun 30, 2011 - 4:05 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
id soak the inside of the drums with some penetration oil like PB blaster and try to drive it a few feet (in reverse would put more pressure) it shuld break it free... then u can spray it with brake cleaner to get the oil off ur rotors
Lo-Fi Version Time is now: November 23rd, 2024 - 12:06 AM
