> 7th gen brake calipers on 6th gen
post Jun 15, 2011 - 3:21 AM
match220
Joined May 13, '06
From Kaimuki, HI
I know I've posted this before, and I know about the long thread about the compatible parts on the 6th gen. I read in the thread that the 7th gen calipers work on the GT as a bolt on. But my question is specifically about the GT convertible. The GT vert has ST tails, and I always have to say it's a GT convertible when I buy parts for it, so I'm not sure how much of the GT vert parts are compatible with the regular GT, or more specifically, I'm not sure if the GT vert calipers can be swapped with the 7th gen calipers/rotors or not. So considering some stuff on my GT vert is also ST (tails), do I have ST brakes or GT brakes?
Also someone told me that the GTS calipers on the 7th gen are different from the calipers on the 7th gen GT. Is this true? If so which one do I get calipers from?
This post has been edited by match220: Jun 15, 2011 - 3:23 AM
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Jun 15, 2011 - 4:19 AM
Johnnyny
Joined Apr 28, '09
From York pa
st tails??? you mean coupe tails and yes you have all around gt brakes and the upgrade is gts 7th gen brakes not the gt
post Jun 15, 2011 - 4:35 AM
match220
Joined May 13, '06
From Kaimuki, HI
yeah, I meant coupe tails, sucks cuz I bought the JDM tails a while back and they didn't fit, I found out I had to use the ones from the curren.
anyway, I have to use the ones from the GTS and not the GT? this link below on ebay, the guy is selling a 7th gen caliper that he says fits both GT and GTS? I'm not saying you're wrong, this is ebay, sellers are wrong a lot of the time.ebay 7th gen caliper
This post has been edited by match220: Jun 15, 2011 - 4:36 AM
-Jay
post Jun 15, 2011 - 7:38 AM
Culpable04
Joined Apr 17, '06
From New Jersey
7th gen GT and GTS has slightly different calipers / disc. and either of them would work on your celica. it doesn't matter if its a vert, GT or ST, the brake will work regardless.
post Jul 7, 2011 - 1:12 PM
Arsaces
Joined Oct 7, '10
QUOTE (Culpable04 @ Jun 15, 2011 - 7:38 AM) *
Hi, sorry to make you repeat yourself, but the OP's post was a bit jumbled and I came away scratching my head. Which 7th gen brakes do we put on the gt 6th gens? Is it a direct bolt on? How much of an upgrade is it? If I decide to buy some calipers I will post a "how-to" however simple it might be, just for reference purposes.
post Jul 7, 2011 - 3:09 PM
match220
Joined May 13, '06
From Kaimuki, HI
i will be making a "how to" once i start this conversion. I have to replace my rotors and pads anyway, so I'm replacing my calipers with them, everything will be 7th gen.
-Jay
post Jul 7, 2011 - 3:43 PM
Arsaces
Joined Oct 7, '10
Could you use 6th gen rotors with 7th gen pads and calipers? Because my rotors are just fine (Almost new). Also would you need gts or gt calipers for a 6th gen gt?
This post has been edited by Arsaces: Jul 7, 2011 - 3:44 PM
post Jul 7, 2011 - 4:00 PM
match220
Joined May 13, '06
From Kaimuki, HI
I don't think so, from what I was reading a while back when you change the calipers you have to change the rotors. The rotors are about 1 inch larger in diameter I think, and the caliper is made for that diameter. They might fit, but the pads might be hanging off the edge of the rotor.
-Jay
post Jul 7, 2011 - 8:36 PM
Arsaces
Joined Oct 7, '10
cool, thanks for the info!
Lo-Fi Version Time is now: February 17th, 2025 - 9:52 AM
