> two wire plug on radiator
post Jun 18, 2011 - 7:30 AM
match220
Joined May 13, '06
From Kaimuki, HI
So I was under my car doing something early this week and I noticed a two wire sensor on the bottom of the radiator. I've never noticed it before. It's an odd place for a water temp sending unit because the water would be cooler in this part of it's cycle, so I don't think it's a water temp sending unit. Sending units are usually on the water outlet side of the engine with the rad fan switch and whatever else. Anyone know what this is?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Jun 18, 2011 - 9:52 AM
its a temp switch for the fans.
post Jun 18, 2011 - 1:39 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (presure2 @ Jun 18, 2011 - 4:52 AM) *
ok, so what are the other two sensors on the water outlet side of the block? I always thought that the one pin sensor was the fan switch, and the two pin sensor was is a temp sending unit.
-Jay
post Jun 26, 2011 - 8:30 AM
QUOTE (match220 @ Jun 18, 2011 - 2:39 PM) *
one is for the dash gauge, the other is for the ECU.
post Jun 30, 2011 - 11:30 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
he is right
(for a GT.)
the 2 pin in the rad is for your fans
the 2 pin on the water neck is for your ecu
the 1 pin on the water neck is for your gauge
(for an ST)
the 2 pin on the water neck is for youe ecu
the 1 pin on the water neck is the fan switch
the 1 pin on the water pump exit pipe is for your gauge
post Jun 30, 2011 - 2:19 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (stephen_lee @ Jun 30, 2011 - 6:30 AM) *
he is right
(for a GT.)
(for an ST)
thanks a lot man, whne I found the one on the rad I thought I had wired something wrong into the Autronic. I couldn't find a good wire diagram so I had wired everything in thinking the two pin on the water neck was from the ecu for temp, and the 1 pin on the water neck was the fan switch for the radiator. Turns out, everything is wired right after all. The one I thought was for the fan switch is for the gauge, and I can leave the one on the radiator untouched.
-Jay
post Jun 30, 2011 - 3:33 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
no problem. glad to help!
5 User(s) are reading this topic (5 Guests and 0 Anonymous Users)
Lo-Fi Version Time is now: February 23rd, 2025 - 8:31 PM
