> 5sfte oil feed lines
post Jun 22, 2011 - 8:02 PM
touandcim
Joined May 21, '11
From Menomonie, wi
Just wondering if anyone has an idea of where I can get some oil feed lines for my upcoming project. Can I use stock oil feed lines from a 3sgte? Also, What about the oil pan? Does the 3sgte pan fit or do I have to tap the stock pan? Lastly, what kind of end fittings on the line do I need and how long does it need to be? I'd love some feedback from someone that has already successfully completed the project.
thanks in advance!
post Jun 22, 2011 - 9:08 PM
D_Dawg
Joined Jul 22, '06
From San Antonio / georgetown, Texas
QUOTE (touandcim @ Jun 22, 2011 - 8:02 PM) *
thanks in advance!
the stock 3sgte lines work if you are using the ct26 turbo. If you use these lines you will need to weld a fitting onto the end of the oil line, i forget the size. The 3sgte oil pan is identical to the 5sfe oil pan with the exception of the oil return line, so you can use the 3sgte pan or tap a hole in the 5sfe pan.
I will be selling the oil lines from my 5sfte celica soon if you are interested, the fittings have been welded already and i have the fitting needed to attach to the oil pressure sensor.
This post has been edited by D_Dawg: Jun 22, 2011 - 9:10 PM
D_Dawg
Joined Jul 22, '06
double post...
This post has been edited by D_Dawg: Jun 22, 2011 - 9:09 PM
post Jun 22, 2011 - 9:19 PM
touandcim
Joined May 21, '11
From Menomonie, wi
sure. just let me know how much.
Lo-Fi Version Time is now: January 11th, 2025 - 9:48 PM
