> Eibach Sportlines Alignment kit?, do i need it?
post Dec 12, 2003 - 2:45 PM
i just placed an order for a set of sportlines, 1.5inch drop. the guy from tirerack said that i should get the alignment kit for the springs. then i call up a local shop and they said that i dont need the kit.
my plan is to try to have a friend do the spring install and then take the car to a shop to have them do an alignment. i figure that a shop should have everything i need to get the alignment done right.
so do i need the alignment kit or not?
Here is a link to the alignment kit im talking about.
This post has been edited by lagos: Dec 12, 2003 - 2:57 PM
post Dec 12, 2003 - 6:38 PM
lagos...no dont buy the kit, you dont need it....all you'll need is an alignment. sorry i havent posted the hoodspoiler PT # for ya, i'll try to get it up there tonight for ya man!
manny
EDIT::: i listed the PT # in the hoodspoiler post in the styling forum..
This post has been edited by presure2: Dec 12, 2003 - 6:52 PM
post Dec 12, 2003 - 9:47 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
The funny part is , you dont even need to do an alignment. your not messing with the setting then your fine....
post Dec 12, 2003 - 11:16 PM
thats good to know...
the sales guy from tire rack made it seem like it was a very important thing to get. so, i wanted to make shure that i dont regret not getting it.
post Dec 13, 2003 - 12:24 PM
Digndoug
Joined Aug 20, '03
From Annapolis, Md
Ok, its if you get lower then i think its 1.75 or really 2. o like if your getting coilovers then you will be i have the sportlines and mines perfect, just with one bald tire... wink.gif
post Dec 13, 2003 - 12:32 PM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
was he possibly talkin about a camber kit? cuz if he was and you have bigger rims I would pick it up - otherwise you will start chewin up tires
post Dec 13, 2003 - 3:37 PM
this is what the description for this kit says
"After the installation of either an Eibach Pro-Kit or Sportline spring set, a vehicles's alignment should always be checked. Once lowered, a wheel's camber may become "increasingly negative," meaning the top of the tire is angled inward (toward the center of the vehicle). While some "negative" camber aids in improving traction and road adhesion, too much can result in peculiar handling and accelerated tire wear.
Eibach offers a complete range of alignment kits which offer a simple, affordable solution to adjust "negative camber." These alignment kits not only assist in adjusting a vehicle's camber back to factory specifications but they also allow the experienced chassis tuner to utilize the increased adjustment range to "dial-in" a performance alignment that uses negative camber to maximize a chassis' potential. Turn-in becomes more precise and handling increasingly crisp and predictable. High-speed stability is also enhanced making an alignment kit from Eibach almost a necessity for the serious performance tuner. "
post Dec 13, 2003 - 6:22 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
It's a camber aligning kit, not a wheel direction alignment kit. You'll need it. When you put bigger rims, the camber changes...just a bit but enough to make a difference. I say buy it.
post Dec 13, 2003 - 10:54 PM
can i just wait and find out if i need it?
im thinking that ill get the springs put on, then go have my alignment and camber checked. if the camber is off, then i can just buy this kit to fix it while the new springs are already on, right?
post Dec 14, 2003 - 12:59 AM
phat94celi
Joined Oct 9, '02
From Longmont, CO
You shouldn't need it. But yeah, you can wait and if you end up needing it you could get it later. I had sportlines on my celi and didn't need it. Of course, I only had 14" rims.
post Dec 14, 2003 - 8:21 AM
lagos...you will not need it....i have sportlines, and 17"s...no need for a camber/alignment kit.
post Dec 14, 2003 - 12:12 PM
ok, i wont get the kit.
man, everyone is so 50/50 on this topic. i just really wanted to make sure that i dont get my springs installed and then find out that i made a mistake and that i have to redo everything to fix the camber.
if i do end up needing some type of camber adjustment, i found out that i can just get some ceap crash bolts from toyota that basicly do the same thing.
i feel better that everyone who has the sprotline+17s combo, didnt need camber adjustment.
post Dec 14, 2003 - 1:43 PM
OOBE
Joined Aug 30, '02
From San Juan, PR
I said get it because it's obvious that when you do something like that, you need a correction on the camber, but you're better off paying attention to the peeps that own or have owned the springs. So far every one of then said you don't need the kit, so go for it. smile.gif
post Dec 20, 2003 - 1:10 PM
Cormudgen
Joined Jul 31, '03
From GA
i have my ground controls maxed out being lowered at 4". granted i'm still riding on the stock 14" wheels. my 18's (with 245/40/18) should be in around the 3rd of january. i'll let you konw if the camber is off then but as of now there is no problem.
cormudgen
post Dec 20, 2003 - 6:33 PM
bojangles_8686
Joined Nov 12, '02
From Baltimore, MD
Ever since I got my car lowered my two front tires wear pretty bad on the inside of the tire, should I get an alignment kit?
-Chucky
post Dec 20, 2003 - 10:02 PM
go get your alignment checked. then youll know if you need the kit. you can also get crash bolts from toyota that will do almost the same thing as the kit, but cost a lot less.
post Dec 21, 2003 - 12:38 AM
Phr0z3n664
Joined Oct 20, '02
From Covington, La
I could've sworn someone said celica's came with adjustable camber.
Am I right?
Pressure2 and Coomer have them(Sportlines). They would be the ones who could answer your questions
post Dec 21, 2003 - 9:02 AM
ConeTrouble
Joined Nov 25, '03
From Mizzeri
QUOTE (Phr0z3n664 @ Dec 21, 2003 - 5:38 AM)
Am I right?
They don't come from the factory with adjustable camber; however, the toe is adjustable (as it is with most cars). They do allow/authorize the use of factory crash bolts to correct camber issues, which you could use to dial in more (or less) negative camber.
My recommendation would be to buy the Toyota bolts as opposed to the ones from that kit. I just ordered 4 and can post the part # in a couple days if needed.
post Dec 21, 2003 - 4:08 PM
ok again.....if your car is lowered less than 1.5/2"s you DO NOT NEED THE ALIGNMENT KIT,
just take your car to any reputable shop & have a 4 wheel alignment done.
Lo-Fi Version Time is now: December 3rd, 2024 - 4:22 PM
