> Clutch pedal spring replacement, Anyone got the part number and/or replaced it before
post Jun 27, 2011 - 5:52 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
Clutch pedal's been soft for the past year or so. Finally decided on replacing the clutch spring behind the pedal. Anyone ever done this before? if you got the part number hit it up also.
post Jun 28, 2011 - 12:50 AM
Smaay
Joined Dec 8, '03
From Lancaster CA
Don't waste your time. The spring has nothing to do with pedal feel. That's all in the design of the pressure plate. If the clutch is still holding then you have nothing to worry about
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jun 28, 2011 - 3:37 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Smaay @ Jun 27, 2011 - 7:50 PM) *
that's the reason why my master keeps going. stock car vs my car, stock car has a better grab/feel
and since my master keeps going I know my disc always active
post Jun 28, 2011 - 4:13 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
90949-03016 / 31353-14010
Torsion Spring / Spring Holder
this should be all i need, we'll see what Toyota says tomorrow.
Still need to know if anyone did this before
This post has been edited by 808celica: Jun 28, 2011 - 4:14 AM
post Jun 28, 2011 - 3:15 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
i think you have another problem. all that spring is for is to assist in pulling the pedal up, there is not alot of tension in it and most of that work is from the pressure plate pushing on the throwout bearing, pushing on the forks, pushing the slave back in pushing the hydraulics back in the system.
post Jun 28, 2011 - 5:37 PM
mkernz22
Joined May 10, '10
From MA
do you need the spring? my friend said you dont actually need it, but with all the **** he thinks he knows, i just thought it would be worth asking.
Lo-Fi Version Time is now: November 23rd, 2024 - 12:13 PM
