First step |
First step |
Jun 28, 2011 - 7:02 PM |
Enthusiast Joined Jun 28, '11 From Maryland Currently Offline Reputation: 0 (0%) |
Okay i have a 1997 celica ST (AT200) 1.8L and its stock everything. Im commited to eventually putting in a ST205 3S-GTE motor but im pretty sure i need a new tranny from a GT-4 model. Is this the E154F tranny? and also, what would be the first steps to getting to my goal? Exhaust? if so, what model because I need alot of help but am commited to getting this done. Thanks
Jun 29, 2011 - 1:47 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
Since the 3S-GTE is turbo, you're going to need a 3" exhaust. So don't worry about that until the swap. A 3" on a NA tiny 4cyl is going to make it choke and suffer.
First steps would be to upgrade the suspension if you ask me. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jun 29, 2011 - 1:53 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
You can't use the 4wd tranny, you need either an mr2 tranny or a v6 camry tranny.
You will also need to change your motor mounts. I would upgrade the brakes 1st, then I would go for the suspention. After that you can think about doing the swap and the exhaust at the same time. |
Jun 30, 2011 - 12:13 AM |
Enthusiast Joined Feb 24, '07 From Oahu, Hawaii Currently Offline Reputation: 23 (100%) |
You can't use the 4wd tranny, you need either an mr2 tranny or a v6 camry tranny. You will also need to change your motor mounts. I would upgrade the brakes 1st, then I would go for the suspention. After that you can think about doing the swap and the exhaust at the same time. you can use the 145F.....you just gotta source a rear cradle and center shaft w/ the center support bearing for everything to work Okay i have a 1997 celica ST (AT200) 1.8L and its stock everything. Im commited to eventually putting in a ST205 3S-GTE motor but im pretty sure i need a new tranny from a GT-4 model. Is this the E154F tranny? and also, what would be the first steps to getting to my goal? Exhaust? if so, what model because I need alot of help but am commited to getting this done. Thanks Alright, first of all welcome to the site The main thing you should do is read up on some old thread of previous pioneer's who have done the swap using the AT chasis, use the search function on the top right of the site and check out Defgeph. He's one of the MODs here and he swapped a 2nd gen 3sgte into his car which I believe WAS an AT chasis 6gc. The trans of choice would be the trans out of a Turbo-2 (MR2 SW20), v6 Camry or ES300......the E153 transmission. of course as you use the Search Function more you'll find that you also can use the S54 trans. Then you read more and you'll find out that you can use the MR-S 1zz LSD in the s54 trans. Find your budget barrier, shop for parts and figure out your total parts list cost. But if you wanna boogie with the 7a motor you got now a good exhaust 2 1/4 piping muffler of choice and suspension goodies and you'll fall in love with the car all over again. Food for thought: Dont build you car fast, you will get bored of it really quick. Thus wanting something else to drive. So take it slow, enjoy the car, build it in a timely matter according to yourself. -808 This post has been edited by 808celica: Jun 30, 2011 - 12:25 AM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 30, 2011 - 2:50 AM |
You can't use the 4wd tranny, you need either an mr2 tranny or a v6 camry tranny. You will also need to change your motor mounts. I would upgrade the brakes 1st, then I would go for the suspention. After that you can think about doing the swap and the exhaust at the same time. you can use the 145F.....you just gotta source a rear cradle and center shaft w/ the center support bearing for everything to work How can you have a 4wd tranny and use it as fwd only? |
Jun 30, 2011 - 3:26 AM |
You can't use the 4wd tranny, you need either an mr2 tranny or a v6 camry tranny. You will also need to change your motor mounts. I would upgrade the brakes 1st, then I would go for the suspention. After that you can think about doing the swap and the exhaust at the same time. you can use the 145F.....you just gotta source a rear cradle and center shaft w/ the center support bearing for everything to work How can you have a 4wd tranny and use it as fwd only? there is nothing in the OP that says he wants the car as fwd only. .....and i guess you didnt get the humor in my first quoted post -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jun 30, 2011 - 2:21 PM |
Enthusiast Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
The E154f CAN be used for fwd, just need to be converted, you end up using the diff out of an mr2 and the cover plate for it
-------------------- 1996 Toyota Celica Project Mean Green
3RD Gen 3SGTE WRC Edition W/LSD E153 - Love BOOST <3 2001 Solar yellow Lexus IS300 2001 Dodge ram 1500 Off-road edition |
Jun 30, 2011 - 2:57 PM |
You can't use the 4wd tranny, you need either an mr2 tranny or a v6 camry tranny. You will also need to change your motor mounts. I would upgrade the brakes 1st, then I would go for the suspention. After that you can think about doing the swap and the exhaust at the same time. you can use the 145F.....you just gotta source a rear cradle and center shaft w/ the center support bearing for everything to work How can you have a 4wd tranny and use it as fwd only? there is nothing in the OP that says he wants the car as fwd only. .....and i guess you didnt get the humor in my first quoted post Yes, I got it hehe. I was just being more serious |
Jul 29, 2011 - 4:58 AM |
Enthusiast Joined Jul 29, '11 From USA Currently Offline Reputation: 0 (0%) |
Jul 29, 2011 - 11:56 AM |
Enthusiast Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) |
As the title says...the First Step would be to do your research....
-------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
Lo-Fi Version | Time is now: January 15th, 2025 - 5:28 AM |
