> 17x9 with offset of 35mm fit our cars?
post Jun 28, 2011 - 10:43 PM
celi_booster
Joined Mar 26, '11
From Wisconsin
I've been searching through this forum and didn't see anyone running 17x9 in the front. Do you guys think 17x9 with an offset of 35mm will fit the front of our cars? Car has a 2" drop.
post Jun 28, 2011 - 11:11 PM
PL-41-ER
Joined May 11, '10
From Australia
I wouldnt recommend it. The wheel might rub against the strut. Not only that, you have a 2" drop. So depending on what tyre you get it will rub against your fender. You would need run negative camber and may need to roll your fenders. So thats probably why no one on here has fitted a 9" wide wheel on the front lol.
I just installed 18x8 +30 with 225/35/18 for the fronts and 18x9 +30 with 245/35/18 for the rears and they sit perfectly. Iv only got a 1" to 1.5" drop.
Hope that helps.
Cheers
This post has been edited by PL-41-ER: Jun 28, 2011 - 11:11 PM
post Jun 29, 2011 - 8:02 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Front fenders come rolled from the factory.
There is a fitment thread that documents size options. Go check it out.
**** Photobucket
post Jun 29, 2011 - 12:31 PM
yellowchinaman
Joined Aug 11, '08
From London
Should be fine. You can fit 45 profiles on them. However the drop is a bit low and mite catch when turning at a heavy front load. It wont touch your struts and even if it does you'll only need about a 5mm spacer to correct it.
post Jun 29, 2011 - 12:34 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
my 18x8 +35 barely clear the strut, and rub on the plastics at full corner, with a 225/40's.
My Celica!
post Jun 29, 2011 - 9:56 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
I'm interested in this as well...
I'm looking into picking up some 17x9 +42 with a 15mm spacer in the front and a 25mm spacer in the rear.
With a +35, I figure I can just adjust the spacers accordingly.
~bloodMoney
post Jun 29, 2011 - 11:19 PM
PL-41-ER
Joined May 11, '10
From Australia
But what look are you guys going for? As in a fat wheel that is in line with the body of the car or do you want it to be hella flush? For instance if you went for the 17x9 +35 wheels on the front, the wheels will stick out 5mm from the fender, which isn't really that much.
And for you Bloodmoney, a +42 wheels with 15mm spacer would make the offset +27 and therefore making the wheel stick out by around 13mm.
But like i said it depends on what look you are going for.
post Jun 30, 2011 - 5:50 AM
celi_booster
Joined Mar 26, '11
From Wisconsin
I want the hella flush look but I wouldn't mind if it sticks out 5mm. Might just have to do some pull and roll on the front fenders. I was just worried that it might not clear the struts. I was planning on getting some Enkei RPF1 17x9 +35 or Rota Grid 17x9 +35
Enkei RPF1
http://www.dezod.com/pd-enkei-rpf11.cfm
Rota Grid
http://cgi.ebay.com/ebaymotors/Rota-GRID-I...sQ5fAccessories
post Jun 30, 2011 - 11:17 AM
PL-41-ER
Joined May 11, '10
From Australia
Well if you're not in a rush i can try to measure the gap on my fronts next week.
Since mine is 8" wide with +30 offset... that would mean the distance from my strut needs to be greater than 17.5mm in order for your wheels to clear the strut.
post Jun 30, 2011 - 4:11 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
I just want a fat wheel that lines up with the body lines. I'm not going for hellaflush, just trying to stuff as meaty wheels and tires as I can under there....
~bloodMoney
post Jun 30, 2011 - 4:22 PM
JDUB
Joined Jun 5, '08
From Portland, Oregon
i wanted those 17x9 rpf1's too but they dont ship out till late sept , im still deciding if i want them still
good luck though
post Jun 30, 2011 - 5:29 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
most ive seen is 235's in front, et35 is good offset, et30 even better, i wouldnt spacer that
Mike W
269awhp / 273ft-lbs
post Jul 27, 2011 - 5:03 PM
94_gt4
Joined Jul 27, '11
From calgary
im not sure if the gt4's have the same sort of base as far as offsets go but this week i should be getting 17x8.25 +25 im still unsure of how easy it will fit once i lower it(STOCK HEIGHT RIGHT NOW) but according to the thread about if theyll fit, it should be almost flush, does anyone have any pics of a setup like this?
post Jul 27, 2011 - 7:03 PM
Promasta
Joined Oct 2, '07
From Manitoba, Canada
gawd those 17x9 rota it-r's would look good with that huge concave, someone please DO IT, they are dirt cheap, $680 shipped brand new
post Mar 24, 2015 - 3:03 PM
Yoitsme_ralph
Joined Jan 28, '15
From Miami,fl
I know this an old thread but I think someone will be interested in my wheels 17x10 all around 20offset [/img]
post Apr 7, 2018 - 12:59 PM
Bazemore6th
Joined Apr 6, '18
From Franklin nc
Hi. I'm new here and have a 1996 toyota celica gt. I have been trying to figure out how wide of a wheel i can go with. Will a 17x8.5 with a 35 offset work and not rub. I don't mind if it bearly sticks out passes the finder lip just want some deep dish on there. Thanks!!
Lo-Fi Version Time is now: February 22nd, 2025 - 9:58 AM
