> awful noise from 3s-gte
post Jun 29, 2011 - 5:09 AM
Gt4Driver
Joined Nov 2, '06
From Finland
Hi! First sorry my bad english.
My car started to keep very awful wheezing noise. car works fine but the noise is something that i cant figure out.
i think it comes somewhere intake?
i hear it all the time when driving, but when i accelerate sound stops.?
maybe i need to get some video for that sound..
post Jun 29, 2011 - 5:44 AM
Gt4Driver
Joined Nov 2, '06
From Finland
http://s1209.photobucket.com/albums/cc400/...ajuttuja009.mp4
post Jun 29, 2011 - 6:17 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Sounds like metal on metal noise...could be wrong though....maybe someone else can chime in..
(\__/)
post Jun 29, 2011 - 7:30 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Check all the nuts that hold the intake-manifold. I've had exactly the same a while ago. Turned out to be a missing nut on the intake, the noise you hear is air.
JDM ST205
post Jun 29, 2011 - 9:59 AM
Gt4Driver
Joined Nov 2, '06
From Finland
yes it sounds like some air leak. have to check the nuts next. thanks for advice:)
i already check all the pipes i could see and they were ok.
post Jun 30, 2011 - 1:43 PM
Gt4Driver
Joined Nov 2, '06
From Finland
how can i check the nuts? do i have to remove engine before i can see them?
very narrow place
post Jun 30, 2011 - 2:40 PM
nsxtypeR
Joined Jan 3, '06
Take a socket (i believe the nuts are size 12mm) with some extensions until you can reach the nuts. It's not easy to access them, the lower ones are best to do from underneath the car. You need patience for sure wink.gif
JDM ST205
post Jul 3, 2011 - 1:52 AM
Gt4Driver
Joined Nov 2, '06
From Finland
good morning!
last night i check the nuts and tight them. did not help. the noise wont go off.
what should i do? im out of ideas.
post Jul 6, 2011 - 5:37 AM
Needles
Joined Nov 18, '10
From montreal
maybe one of the belt or idler pulley make that noise, just a suggestion, i never heard that sound before
post Jul 6, 2011 - 8:00 AM
3WayStunna
Joined Jun 25, '06
Sounds like something metal vibrating at low rpms. Sound is annoying as all hell and i can understand why you would want to find out what it is...if i were you, i would go over anything i ever messed with before the sound started....if that brings you no results, then at least you have narrowed things down a bit.
Next think logically about what could of gone wrong to cause that noise...i mean it had to just happened right? Or has it been something you dealt with since you owned the car? Either way work from their AFTER you have checked over any and everything you have messed with before the noise started...
(\__/)
post Jul 6, 2011 - 11:04 AM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
sounds like the noise i had when my original ct20b bent the shaft and the compressor wheel was scraping the housing, the whole turbo unit was throw away..
ended up being worn bearings finally giving out cuz the oil feed was carboned up
Mike W
269awhp / 273ft-lbs
post Jul 6, 2011 - 4:43 PM
cax_11
Joined Aug 15, '10
From Nevis, West Indies
check all air hoses, and every other piping that goes to the intake manifold, I'm almost certain its an airleak, the fact that it goes away when you hit the accelerator makes me think that, the air pressure changes when you press the gas causes the sound to go away, you can also use a plastic pipe to narrow down where the sound is coming from, the way your gonna do this is by, putting one end of the pipe to your ear and block off the other ear and move the other end of the hose around until you can hear the sound intensifying, it should put you directly ontop of the noise source and you can go on investigating from there. rolleyes.gif
1994 Toyota Celica GT-Four ST205 Turbo 4WD, Black
Nevis, West Indies
post Jul 11, 2011 - 4:27 PM
Gt4Driver
Joined Nov 2, '06
From Finland
Hi! Could this be my solution?
one of my injector sealing looked like this. other three was ok. itīs not easy to remove the intake manifold. so maybe i just replace those gasgets.
what do you guys think?
post Jul 11, 2011 - 4:52 PM
playboymma
Joined Jan 7, '11
From Mena, AR
that REALLY sounds like a vacuum leak
I went full retard once, too. Its OK.
post Jul 11, 2011 - 5:10 PM
Gt4Driver
Joined Nov 2, '06
From Finland
could this cause that?
post Jul 11, 2011 - 11:42 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
thats exactly what the problem is. replace all 4 of those gaskets while you have the manifold off
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 15, 2011 - 10:51 PM
Gt4Driver
Joined Nov 2, '06
From Finland
ok. yesterday i put new seals in and start putting parts together..
Today have to go to work, after that intercooler goes in and ready to start smile.gif
ofcourse first new oils and coolant water.
post Jul 16, 2011 - 10:54 AM
Gt4Driver
Joined Nov 2, '06
From Finland
I start my car today and let it idle. The sound was gone..
After one or two minutes The ****ing noise started..
and i havent done the car anything else but installed boost controller. and i take it off yesterday. so the car is standard. except exhaust.
post Jul 20, 2011 - 11:44 AM
Gt4Driver
Joined Nov 2, '06
From Finland
ok. i have been searchin where that noise is coming from. and i think it comes somewhere under the distributor.
there is some pipes and next i replace those.
something that i noticed. when the motor is cold the noise is almos gone. but after couple minutes it jus get louder or if i touch the gas pedal.
all help you can give will be worthless.
post Jul 20, 2011 - 4:41 PM
Terracar
Joined Mar 28, '08
From Washignton
that does sound metal on metal rotational contact. (like a bearing). Since I believe it is related to the compressor wheel and possible contact with housing or a bearing I would suggest this as a check...
When the engine is idling and making the noise, disconnect one of the couplers from the intercooler - effectively letting the turbo just blow to the atmosphere. If it stops, I would say it is turbo related.
Do not do this check while revving the engine or in a dusty location. Do no drive the car like this as this is only a diagnostic check.
-Terracar
'92 ST185, '88 ST165, '05 Galant LS, '08 Legacy
Lo-Fi Version Time is now: January 9th, 2025 - 2:17 AM
