3 Pages V  < 1 2 3
> Most Bang for the Buck
post Jan 8, 2004 - 10:58 AM
I've said it before, and I'll say it again...Nitrous is like heroin, sall good til you car is dead in the gutter.
post Jan 8, 2004 - 11:26 AM
NEVERSTOP
Joined Nov 4, '02
From Davenport Iowa
Even with a turbo or s/c you can still mess up your engine. If you go past the recommended settings for how your motor is built. Actually driving your car hard all the time can do it too. Nitrous isn't the culprit. It's how its used.
As for using nitrous.. well im for it in small doses - I personally plan on running a zex ( or venom if I can get the cash for it) system that will hook into my intercooler in a effort to charge the air even more, that way when it reaches my motor the NO2 is mixed a little better with the oxygen.
Most cars can handle a 75hp shot on stock internals as long as it is used properly and wisely... granted there is not 100% on anything
The best thing you can do when running NO2 is to check you spark plugs reguarly, they will be the 1st sign of problems with carbon build up inside your head.
Another cheaper alternative is to run propane instead of NO2... basically you set it up just like nitrous but it burns cleaner and is just as affective, I personally havent do this but have heard alot about it for years and know a few older hotrodders that do it with no probs.
another trick you can use at the track that will yeild you results (2 tenths or better) is to build a box or use a small refirigurator(sp?) and hook your NO2 bottle to it so it sprays into the box/refiriguator and place your filter in there and let it soak for a few mins before your run, my dad used to do this with one of his 67 firebirds and it worked great for him - made the difference between 11 and 10 sec 1/4's biggrin.gif
.. If you are considering things like a 100hp jump than I STRONGLY RECCOMEND you upgrade your BREAKS!! otherwise you'll end up like Paris hilton, wrapped around a pole!
post Jan 8, 2004 - 11:27 AM
Uppitycracker
Joined Jul 12, '03
From Chatham, Ont
Does nitrous bug anyone else here? its like fake hp, reminds me of a video game, press the red button for momentary boost, instead of crafting a performence engine that is fast all the time, stupid kids....
3 Pages V  < 1 2 3
Lo-Fi Version Time is now: November 27th, 2024 - 6:46 PM
