left side lights, left turn signal acting wierd, no rear lights |
Jul 6, 2011 - 7:27 PM |
Enthusiast Joined Jan 13, '11 From vandenberg afb, ca Currently Offline Reputation: 0 (0%) |
Okay so when I use my left turn signal, it the indicator stays lit and makes a loud annoying sound. The turn signal doesn't work at all, and the indicator stays on without it blinking like usual. Also, my left rear lights aren't working aswell.. and high beams don't work. I'm not good with electrical stuff, any suggestions?
Jul 7, 2011 - 10:53 PM |
bump...
Jul 7, 2011 - 11:05 PM |
Enthusiast Joined Feb 20, '08 From Abingdon, Maryland Currently Offline Reputation: 7 (100%) |
Both left turn signals aren't working? Both front and back? Did you replace either of the bulbs recently? Maybe wrong bulb type or put the bulb in backwards?
Besides that, it could be a short in the bulb socket which would explain why your indicator would stay lit. it could be in the rear which would explain possibly why the whole rear section is out on the left side of your car. And do both high beams not work out just the left high beam? |
Jul 7, 2011 - 11:59 PM |
Both left turn signals aren't working? Both front and back? Did you replace either of the bulbs recently? Maybe wrong bulb type or put the bulb in backwards? Besides that, it could be a short in the bulb socket which would explain why your indicator would stay lit. it could be in the rear which would explain possibly why the whole rear section is out on the left side of your car. And do both high beams not work out just the left high beam? As for the turn signals it the front and back for the left side. I have not replaced the bulbs but when i checked them, they seemed good. None of the high beams work. As far as short, how can i figure it out if it is or not? and how can i fix that? thanks for responding! |
Lo-Fi Version | Time is now: November 26th, 2024 - 3:18 PM |
