> Anyone think of moding their AC to make it blow colder??
post Jul 15, 2011 - 8:48 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
Here in TX it gets 110 and HIGH humidity.. so in the middle of the day my ac barely blows 55-60*.. keeping it quite warm in the car still. So has anyone tried adding a second condenser and fan to the AC system? Or is there another way to make it blow any colder? It has a good freon charge, and i already added insulation around the lines to the evaporator..
post Jul 15, 2011 - 9:16 AM
jimmykay
Joined Jul 14, '08
From St. Louis
While I'm glad that I don't have to deal with the TX heat right now. I think that my problem in my car isn't the AC, it blows cold enough, but rather the lack of insulation and abundance of glass in the car means that it warms back up quickly.
Air conditioning works off of a temperature differential. If it's 110 outside and you're still pulling 55 degree air through. That's better than the air conditioner in my house.
With that said, instead of a second AC unit, one possibility might be that you may want to start looking into swapping out a bigger compressor. maybe something out of a seinna or a tundra would be bigger. Good luck.
'99 Celica GT - Sold
'11 Mazdaspeed3
post Jul 15, 2011 - 9:55 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i didnt mean a whole second ac unit, just adding a second condenser in line with out stock one. although a larger compressor might increase the refrigerant flow/pressure, it might not make much a difference since then it would have less time cooling in the condenser and therefore being hotter going into the evap core. hotter liquid and more flow may mean same temperature or even warmer.. plus the expansion valve will still only allow X amount of refrigerant flow.
I was thinking having more evaporator surface area will allow a better drop in temperature no matter how warm it is outside. Also an increase in refigerant would mean it would have even longer in each part.
I have thoroughly insulated my car, too. all the body panels have foil/foam insulation including the roof floor and doors, and the quarter panels are full fiberglass. the doors have 2inch sheets of backed & duct taped fiberglass as well. under the carpet is also carpet padding. but you're totally right about the windows... maybe i should get darker tint first and see how it helps.
post Jul 15, 2011 - 10:40 AM
jimmykay
Joined Jul 14, '08
From St. Louis
darker tint would be a much easier and cheaper fix. hang in there, this heat should pass in the next month or two kindasad.gif
'11 Mazdaspeed3
post Jul 15, 2011 - 12:15 PM
see my lines...
it helps a little...
post Jul 15, 2011 - 12:23 PM
azian_advanced
Joined Apr 18, '05
From Calgary
i'm sure toyota designed the condenser & fan so that the refridgerant will completely condense while using the stock AC compresser even in very hot weather. in this case upgrading the condenser alone won't make the refridgerant any cooler. the easiest way to make the system blow cooler would be to upgrade the compressor and upgrade the condenser & fan (to compensate for the higher refridgerant pressures). but i would prefer insulating the car and tinting the windows than upgrade the AC system since these don't cost any hp from the engine. i use a 2-way alarm/starter to prestart the car so it's cold when i get in which helps a lot, especially when my 2-way remote displays the interior temperature so i know what i'm getting into before getting into the car.
post Jul 15, 2011 - 12:32 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
I did the insulation around those lines already. I've been in plenty GM and ford cars that blOw ice cold nearly instantly even in super hot weather. I know out condensers take a beating from rocks maybe it needs to be replaced. Also a 16 yr old expansion valve may be less than working properly. I'm just thinking it won't take much effort to add a second condenser plus I can get the parts cheap. Since my system would be open might as well do it all.. Condenser, expansion valve and dryer.
post Jul 15, 2011 - 1:05 PM
azian_advanced
Joined Apr 18, '05
From Calgary
mine blows ice cold but takes about 30 secs to a minute of idle in 90 degree outer temperatures.. and less if i'm driving. i recently rented a new ford escape and chrysler sebring here in vegas, and while they blow cold in less time while idling, they're able to do this because ford & chrysler may have put higher performing compressors since both cars have higher hp engines (V6) compared to the celica.
post Jul 18, 2011 - 1:25 PM
boomer
Joined Jan 26, '11
From ontario canada
QUOTE (stephen_lee @ Jul 15, 2011 - 8:48 AM) *
had simalar problem this spring ice cold last year only blowing 56/60 this year had full freon charge. suggest you check your high and low pressure readings mine were erratic . changed tx valve and dryer . now blows 35/40 even when driving or idling in high 90s
post Jul 18, 2011 - 1:38 PM
cyprus_gt
Joined Jan 16, '09
From Cyprus
I am from Cyprus so here during the summer is 40 degree normaly and..
...when i start my car i need 10 seconds and the AC start blow so cold so i need to turn the fan less!
Just need to check your system - the celica that i have is SS2 1994 year and is the most cold AC that i ever driven
cheers
post Jul 30, 2011 - 10:57 AM
r-12 = colder than r134.
post Aug 2, 2011 - 2:34 AM
Hanyo
Joined Aug 16, '03
From Bay area
a second condenser fan would only help if your driving around in town. When your on the highway, our condenser gets more then enough air to flow over it to cool the freon. So the coldest our ac system can get is when your driving on the high way.
post Aug 2, 2011 - 7:45 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
on the HWY it blows 45-50 so it IS an airflow/condenser efficiency issue. stopped and revv the motor doesnt change temp much
post Aug 4, 2011 - 1:36 AM
opie_7afe
Joined Feb 26, '11
From beaufort,SC
have you checked to make sure your cooling coil is nice and clean and not full of dust/muck?
post Aug 4, 2011 - 1:04 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
what about modding the heater to blow hotter, thats what i wanna do, i was thinking of smoothing off the sharp turn in the end of the water outlet, possibly enlarging it ever so slightly and shortening the hoses??
Mike W
269awhp / 273ft-lbs
post Aug 4, 2011 - 1:55 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
my heater blows FAWKIN hot. close to 200. i bet your core is plugged. but i imagine if u find some sort of small electric pump to push coolant through there faster it'd blow hotter, but remember, you can only blow a max of 180-200 degreees
post Aug 4, 2011 - 5:32 PM
delusionz
Joined Feb 11, '08
i live in a cold climate.,,,
its middle of winter right now...
sometimes have to turn it all the way unless i drive the car hard then all of a sudden really hot are blasts thru ...
Mike W
269awhp / 273ft-lbs
post Aug 18, 2011 - 3:09 AM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (azian_advanced @ Jul 15, 2011 - 7:23 AM) *
depending on the cooling system, sometimes you can't just upgrade the compressor or add more refrigerant. You would have to change out the high or low pressure switches too. Adding more refrigerant adds more pressure. So the compressor will come on quick and shut off quick, or too little refrigerant will keep it on longer. The switches on the high and low presure lines are designed to shut off the compressor if the high high pressure switch senses too much pressure or come back on when the low pressure switch senses too little pressure. With that said though, I don't know how the celica cooling system functions because I've never had to troubleshoot it, but I have troubleshot other ones, and that aren't all exactly the same. Some have a high/low pressure switch combo, some have separate, and some just have one.
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Aug 18, 2011 - 9:00 AM
stephen_lee
Joined Mar 22, '07
From Houston, TX
we have a hi-low pressure switch, and a block style expansion valve. adding a larger condenser and more refrigerant will not affect the pressures much as there is more room for the r134 to take up in the additional condenser space. Also an additional fan, or higher CFM replacements for stock, will allow lower temperatures in the condenser and therefore lower pressures.
post Aug 18, 2011 - 3:21 PM
Steven, its really as simple as converting to r12 if you want it colder. But before you do, are your reciever and drier in good working order? I'd be willing to bet that is part of your problem.
Lo-Fi Version Time is now: November 22nd, 2024 - 3:42 PM
