Depressed after putting 17s on, brb less power, less handling, less braking |
Jul 21, 2011 - 9:05 PM |
Enthusiast Joined Dec 23, '10 From PA, USA Currently Offline Reputation: 0 (0%) |
performance in all categories has decreased.
What have you guys done to remedy this problem? I can definitely tell I need lowered now more than ever because of the hightened center of gravity. My tires currently are 215/50/17....hopefully some 215/45s will give me a bit more of my power back. blah. |
Jul 21, 2011 - 9:16 PM |
Also like to add that it made my steering feel a lot heavier...I know this is just because the wheels are heavier, but it doesn't feel good.
Jul 21, 2011 - 9:22 PM |
I went from 14" steelies to 17" wheels, so I know what you mean. 215/45/17 tires would probably improve the areas of complaint in all respects.
'93 MX-5 LE |
Jul 21, 2011 - 11:12 PM |
Enthusiast Joined May 31, '11 From Rochester, NY Currently Offline Reputation: 5 (100%) |
I'd say a smaller tread patch... If you think about it, the contact patch on a 215 is huge. Lower it to a 205 and you should have a better result. You can rock a 205/50 comfortably since it's a balance up from OEM size. I'd never go wider on a tire than OE spec, but if you go taller, always go skinnier. Same rule applies to wider. But, regardless 215 is a large tread.
What rims did you get? Those are OEM SCION TC specs lol. -------------------- 1994 Toyota Celica GT-S 5S-FE 190k Miles. Project car 1992 Toyota Celica GT 5S-FE 170k Miles. Daily driver/beater 1999 Toyota Camry LE 5S-FE 216K Miles. RIP You will be missed. *ASE Certified General Manager |
Jul 22, 2011 - 12:31 AM |
changing to a 45 won't make much of a difference. most of the performance loss comes from the weight of the wheels. lightweight and smaller wheels will give you better acceleration, braking, and handling. 17s are mainly just for looks. when i switched to 17s it made a noticeable difference and the car felt a lot slower, but after a while of driving you get used to it.
Jul 22, 2011 - 3:21 AM |
hmm why did you get 215/50R17 in the first place? I'm assuming to fill the wheel gap.
get your self some 215/45R17 tires and lowerings springs and you should be set. -------------------- Group buy to replicate Narrow E series transaxle parts
Jul 22, 2011 - 3:26 AM |
Enthusiast Joined Aug 13, '08 From Australia Currently Offline Reputation: 7 (100%) |
Go back to stock rims, and wrap street semis and run-a-muck!!!!
Jul 22, 2011 - 8:23 AM |
Enthusiast Joined Dec 3, '08 From Summerville, SC Currently Offline Reputation: 0 (0%) |
When I put 17s on my Celica I didn't notice a single bit of difference in performance. It's more the weight of the wheel than tire spec. It's more rolling mass that your car has to get moving. I'm running a 245/35/19 and 275/30/19 on my Lexus, the performance aspect is phenominal!!! Ride is a little rough due to almost no sidewall though
-------------------- www.tweakdperformance.com
sales@tweakdperformance.com |
Jul 22, 2011 - 5:01 PM |
Enthusiast Joined Dec 11, '07 From Davie, Florida Currently Offline Reputation: 4 (100%) |
When I put 17s on my Celica I didn't notice a single bit of difference in performance. It's more the weight of the wheel than tire spec. It's more rolling mass that your car has to get moving. I'm running a 245/35/19 and 275/30/19 on my Lexus, the performance aspect is phenominal!!! Ride is a little rough due to almost no sidewall though Throw in a 3S and you'll have a change of heart Lol, just kidding. I know exactly how you feel. I used to have a staggered set of 18's & the acceleration went downhill, but I got accustomed to it. After a month or so, if you are still bothered by it, switch back to smaller wheels. Just my .02 cents. -Ryan When I put 17s on my Celica I didn't notice a single bit of difference in performance. It's more the weight of the wheel than tire spec. It's more rolling mass that your car has to get moving. I'm running a 245/35/19 and 275/30/19 on my Lexus, the performance aspect is phenominal!!! Ride is a little rough due to almost no sidewall though Throw in a 3S and you'll have a change of heart Lol, just kidding. I know exactly how you feel. I used to have a staggered set of 18's & the acceleration went downhill, but I got accustomed to it. After a month or so, if you are still bothered by it, switch back to smaller wheels. Just my .02 cents. -Ryan |
Jul 22, 2011 - 6:56 PM |
Enthusiast Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
From what I've read the 17" matrix wheels weigh in at around 27lbs for just the wheel. The stock 15"gt wheels are between 16.5-17lbs each. So that's a big difference and your acceleration, handling, braking and gas mileage will suffer. I went with the 17" tC wheels which weigh in at around 21lbs each. Your choices are either live with the wheels you have or swap them out for something lighter.
This post has been edited by bmj67: Jul 23, 2011 - 10:11 PM |
Jul 22, 2011 - 7:10 PM |
From what I've read the 17" matrix wheels weigh in at around 27lbs for just the wheel. The stock 15"gt wheels are between 16.5-17lbs each. So that's a big difference and your acceleration, handling, braking and gas mileage will be suffer. I went with the 17" tC wheels which weigh in at around 21lbs each. Your choices are either live with the wheels you have or swap them out for something lighter. WHOA! 27lbs is a LOT for a 17' wheel. The wheels I'm looking to get are 18's and they weigh in at a little less than 22 lbs. There's your problem. The power from your car is being sucked by the weight of your wheels. |
Jul 23, 2011 - 10:55 AM |
From what I've read the 17" matrix wheels weigh in at around 27lbs for just the wheel. The stock 15"gt wheels are between 16.5-17lbs each. So that's a big difference and your acceleration, handling, braking and gas mileage will be suffer. I went with the 17" tC wheels which weigh in at around 21lbs each. Your choices are either live with the wheels you have or swap them out for something lighter. Whaaaat??? 27lbs each? ****. I may have to find some new wheels... |
Jul 24, 2011 - 2:49 PM |
17 lbs? really? the stock 15" GT alloys?
This post has been edited by stephen_lee: Jul 25, 2011 - 11:57 AM -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 25, 2011 - 12:15 AM |
the gt wheels are 15"
Jul 25, 2011 - 11:58 AM |
oops. youre right. but they feel lighter to me...
ive got a set at home without tires, but no scale -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Jul 25, 2011 - 12:49 PM |
Enthusiast Joined Oct 18, '06 From cincinnati Currently Offline Reputation: 10 (100%) |
yea, how heavy are the 17's you put on it? mine are pretty lightweight and weigh almost the same as the 15 BBS's that came stock on my celi
-------------------- proud =3sgte SWAPPED= '95 Celica ST owner [calling it the GT2 or half-trac]
309,000 miles n' .... |
Jul 25, 2011 - 2:30 PM |
Enthusiast Joined Oct 28, '09 From North East, UK. Currently Offline Reputation: 0 (0%) |
Splash out on some volks
My 18" Ce28N weigh in at 6.7kg (14.7lbs) -------------------- |
Jul 25, 2011 - 2:36 PM |
Enthusiast Joined Jan 19, '11 From Paraguay, Winchestertonfieldville Currently Offline Reputation: 1 (100%) |
regular OZ wheels are about 8 kgs and cast wheels are around 10-12 kilograms..I dont know about you but I think 17" is the best there is in relation to looks/handling/performance when it comes to taking it to the track...i put 225's 17 55 on the gt four and It is a relief to not skid around and get amazing launches...But then again second reviews to come when i finish the beast, still got to put the whole thing together with new suspension and a diff cushion
Jul 25, 2011 - 5:52 PM |
Well I'm moving tire size down to 215/45/17 |
Jul 25, 2011 - 6:41 PM |
Enthusiast Joined Mar 6, '04 From Charlotte, NC Currently Offline Reputation: 9 (100%) |
Be prepared to continue being disappointed because the weight is still going to be substantial; I'm running 215//45/17 on tC wheels and the combined weight is about 40 pounds at each corner compared to the stock 15's on 205/55/15 weighing about 36lbs.
At this point, knowing what I do now if I had a chance to do it again I'd either choose 16" GT-S rims or pay for very light 17s. Good luck. This post has been edited by Keiri: Jul 25, 2011 - 6:42 PM -------------------- Has no more Celicas
Lo-Fi Version | Time is now: November 27th, 2024 - 11:02 AM |
