> dry sump 3sgte
post Jul 25, 2011 - 11:53 PM
match220
Joined May 13, '06
From Kaimuki, HI
I found these pictures online, I was wondering if anyone knows where to buy dry sump parts for the 3sgte. I never knew anyone sold them.
For those of you that don't know what "dry sump" is...it's opposite from the 3sgte's normal "wet sump" style. A wet sump sucks the oil from the pan and the oil is used and then drained and held in the pan, a dry sump setup eliminates the oil pan, the oil is sucked out of the pan and held in a bottle. This allows the engine to be mounted lower in the engine bay, which gives the car a lower center of gravity. Most high end sports cars have the engines designed this way to drop the engine mass about 3 - 5 inches. It helps on cornering.
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Jul 26, 2011 - 6:48 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
it also helps with oil pickup, its not sloshing around and causing starvation issues. this happens alot in 2ZZs
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Jul 27, 2011 - 7:11 AM
3WayStunna
Joined Jun 25, '06
From Box Elder, South Dakota
Try talking to the guys over at cantonracingproducts.com and see if they have any ideas for you. Ive heard that they have worked with 3s oil systems before. Or you can ask on the toysport forums or fensport folks....
What do you plan on using a dry sump system on btw?
And why? Are you having oil starvation issues or will you be doing something that would require it?
EDIT:
Btw your interest in this has caused me to google search my booty off and i came across this article on toymods.au...
http://www.toymods.org.au/forums/tech-conv...nstruction.html
also think racerx from the MR2 forums is making dry sump systems as well
http://www.racerxfabrication.com/page1/page1.html
Honestly though, for a dry sumps systems complexity wouldnt a crank scrapper/windage tray be better idea for most applications?
This post has been edited by 3WayStunna: Jul 27, 2011 - 9:07 AM
(\__/)
post Jul 27, 2011 - 3:16 PM
match220
Joined May 13, '06
From Kaimuki, HI
just an idea. I would like to be able to drop my engine a few inches lower in the engine bay and reweld my motormounts. Just one of my ideas that I mull over in my head every now and then. I probably won't end up doing it, but I like reading and researching the options
-Jay
Lo-Fi Version Time is now: November 23rd, 2024 - 11:20 AM
