2 Pages V  < 1 2
> BC racing BR Coilover install
post Oct 4, 2011 - 11:23 PM
drumbum
Joined Nov 29, '09
From Milwaukee
QUOTE (white_light808 @ Oct 4, 2011 - 12:39 AM) *
is that the ride height right out of the box? im thinking about grabbing a set in about a month or so smile.gif
It is not right out of the box... they are packaged way to low... as in they won't even work that low... only the fronts if i remember right... But you can adjust them a lot more lower than i have... you could probably slam it with them if you wanted to
Weekend Warrior-----1998 Celica GT: White
Daily Driver----------1997 Celica GT: Blurple
post Oct 5, 2011 - 2:44 AM
malpaso
Joined Feb 3, '06
From Czech Republic (Europe)
You must have roads flat as glass smile.gif . I have on my BCs height like this and suffer as hell in CZ:
can you see scratched splitters? or how is under-panel scratched? When changing tires next months I will raise it for half and inch for sure. I have learned like this it is not drivable on 25% of roads here kindasad.gif
This post has been edited by malpaso: Oct 6, 2011 - 3:04 AM
post Oct 6, 2011 - 9:41 PM
drumbum
Joined Nov 29, '09
From Milwaukee
we actually have terrible roads here... i am just really cautious on the side roads but the highways are ok... haven't had any problems except over this one set of railroad tracks haha... what are your settings??
post Oct 7, 2011 - 4:44 AM
malpaso
Joined Feb 3, '06
QUOTE (drumbum @ Oct 7, 2011 - 4:41 AM) *
When was brand new I used 64.5cm (25.4inch) rear and 61.5cm (24.2inch) front. But after 1000-2000miles it "settled down" for sure (I touch everything around more than before smile.gif). Do not know how much because I have not measured it yet. This will happen in few weeks when I will raise it. Than let you know how much they dropped them selves.
This post has been edited by malpaso: Oct 7, 2011 - 4:45 AM
post Mar 30, 2017 - 5:03 PM
Kimyota99
Joined Nov 12, '15
From Los angeles, California
This is really late but, how was the install? Was it a plug and play or was there welding involved ?
post Mar 31, 2017 - 8:35 AM
jordisonjr
Joined Jan 20, '09
From Winnipeg
QUOTE (Kimyota99 @ Mar 30, 2017 - 5:03 PM) *
This will be plug and play on a GT or ST chassis.
If its a ST205, or any other variant that uses the super strut suspension, there will be some cutting and welding required.
EDIT: I see you've got a convertible. This should fit no problem.
This post has been edited by jordisonjr: Mar 31, 2017 - 8:36 AM
My Celica!
2 Pages V  < 1 2
Lo-Fi Version Time is now: November 30th, 2024 - 1:05 AM
