Midwest Meet v3- Sept. 24th, 2011., The Secret Meeting Spot. |
Sep 26, 2011 - 12:28 AM |
Enthusiast Joined Sep 28, '09 From Washington, MO Currently Offline Reputation: 0 (0%) |
I'm bringing: Gas Grill Gas Plates Plastic wares Paper plates Cups Paper Towels Baby wipes Condoms Anal Lube i could have definitely used the lube, 'cause karma apparently felt above the condoms... and yea, i made it back ok... took until 4am 'cause andrew insisted on still going by the strip club on the way back... sadly, in the same note as the rest of my life, my car's having problems getting proper lubrication at the moment... chris was right about the piston rings i think, 'cause my oil smells like 93 octane. i guess more than just the turbo, ecu, alternator, catalytic converter, charge cooler level sensor, and distributor cap were crapped out on the motor i got from jim... apparently so were the piston rings, power steering pump, and dump valve. hopefully by the time the spring meet comes around i SHOULD have a new 3S in there. as soon as i come up with the $2k or however much for a new 3rd rev 3S or at least a long-block (with power steering pump and dump valve, and probably map sensor, O2 sensor, and tps sensor since those are about all i haven't already had to replace off this engine)... since everything's already set up and i know what it looks like, this time i will be doing the swap myself. anyone in the st louis area have an open garage i could use? |
Sep 26, 2011 - 11:25 AM |
Enthusiast Joined Jan 7, '11 From Chicago, IL Currently Offline Reputation: 1 (100%) |
Bitter--- the cookies I made were just Betty Crocker cookie dough mix in the bag (found with the cake baking stuff-- only needs a stick of butter and an egg added). I made 2 bags and took abt a bag and a half and spread it out in a pan (make sure its not toooo thick though or it wont bake right), poured a bag and a half of semi sweet chocolate chips over the top (can be melted and poured over if desired), then took the left over dough and put clumps spread out somewhere around an inch apart across the top, then bake until solid all the way through.
Very easy to do-- I experimented w that batch to see how it would turn out. Ill make it again for the next meet as well since it seemed to go over pretty well. if you decide to make it and have questions or whatever just give me a call. -------------------- 94 ST--- Project Fury |
Oct 4, 2011 - 7:15 PM |
We doing one more of the year? Mazda is coming out if we are, the heat in it will give you a rash.
Oct 4, 2011 - 7:18 PM |
Enthusiast Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
We doing one more of the year? Mazda is coming out if we are, the heat in it will give you a rash. I'm up for it if others are. -------------------- |
Oct 4, 2011 - 8:17 PM |
We doing one more of the year? Mazda is coming out if we are, the heat in it will give you a rash. I'm up for it if others are. this. -------------------- 94 ST--- Project Fury |
Oct 4, 2011 - 8:24 PM |
We doing one more of the year? Mazda is coming out if we are, the heat in it will give you a rash. I'm up for it if others are. this. Is -------------------- |
Oct 4, 2011 - 8:38 PM |
Enthusiast Joined Aug 17, '09 From Millard, Omaha, Nebraska Currently Offline Reputation: 1 (100%) |
We doing one more of the year? Mazda is coming out if we are, the heat in it will give you a rash. I'm up for it if others are. this. Is Not... going to happen. |
Oct 4, 2011 - 9:01 PM |
Maybe not for everyone, but more local people it could.
Winter meet! We can hike to see the frozen waterfalls. -------------------- |
Oct 4, 2011 - 10:54 PM |
Enthusiast Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
I'm down for sure!
Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Lo-Fi Version | Time is now: November 23rd, 2024 - 3:34 AM |
