srs indicator post 3rd gen swap |
Jul 30, 2011 - 4:15 PM |
Enthusiast Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
For those with 3rd Gen 3sgte, does your srs warning indictator light up when the key is put to acc or on position? Its supposed to be on for 6 seconds. My wiring is the same as from presure2's swap.
This post has been edited by purplegt4: Aug 9, 2011 - 1:09 PM |
Jul 30, 2011 - 7:23 PM |
If it's not wired in, then it won't come on.
Aug 5, 2011 - 1:14 PM |
I found the srs wire in the old engine harness.
Aug 6, 2011 - 1:22 PM |
Success!
Aug 9, 2011 - 1:34 PM |
In the case you forgot your airbag light on your 3sgte:
According to this diagram: If you look into the missing hole, there will be no wire plugged in. The top hole is connected to the battery, the bottom one to nothing. view from underneath. That blue wire must be routed to pin#2 Of this plug plug #4 (labeled on my 7a harness) this is the connector on the opposite end of the harness, past the ecu connectors. This post has been edited by purplegt4: Jul 7, 2014 - 11:02 PM |
Lo-Fi Version | Time is now: December 3rd, 2024 - 5:29 AM |
