> compressor eliminator OR Gen III 3sgte compressor info
post Jul 31, 2011 - 9:09 PM
match220
Joined May 13, '06
From Kaimuki, HI
I am looking for information on either what type of compressor is used on a 3sgte after the swap has been done, or where I can find a compressor eliminator bracket/pulley. I tried to use my 5sfe compressor and I realized that it fits but the thermostat housing bumps the compressor. What cooling tubes/compressor work on the car when trying to use the old 5s system with the Gen III 3sgte engine?
-Jay
95 GT conv. project car: Manual, Gen III 3sgte, JN pisons, Eagle rods, overbore, crank knife-edged, crank scraper, ARP head/main/flywheel, Autronic EMS, Haltech Dual Wideband O2 controller, Audi 1.8T individual coils, FMIC and SSQV BOV, 3" downpipe, 3" ultra-high-flow cat, 2.5" Borla muffler, +other
01 S2000: FMIC, Haltech EMS, Haltech wideband, 570cc inj, forged pistons/rods, sleeved block, 5 angle valve job, ported and polished
02 R6, all stock, except for braided stainless brake lines, frame sliders, and adjustable brake/clutch leve
post Aug 1, 2011 - 5:42 AM
3s compressor, 5s lines.
post Aug 1, 2011 - 6:20 AM
match220
Joined May 13, '06
From Kaimuki, HI
so can i use a gen 2 3s compressor instead of a gen 3 compressor? I know it will mount into the block but are the lines the same?
-Jay
post Aug 1, 2011 - 6:24 PM
I don't think the gen2 is the same.
post Aug 2, 2011 - 6:29 AM
QUOTE (match220 @ Aug 1, 2011 - 7:20 AM) *
The lines on the 2nd gen compressor are not the same. You can either use a 3rd gen one, or a stock 5sfe one. I'm using my 5sfe one and it works great.
post Aug 2, 2011 - 3:02 PM
match220
Joined May 13, '06
From Kaimuki, HI
QUOTE (lagos @ Aug 2, 2011 - 1:29 AM) *
I don't know about that. I have a stock 5sfe comp mounted to a 3rd gen 3s block and my thermostat housing is bumping the edge of the compressor where the radiator hose fits on. It looks like it will almost work, I haven't tried fitting a rad hose yet.
-Jay
post Aug 2, 2011 - 10:23 PM
QUOTE (match220 @ Aug 2, 2011 - 4:02 PM) *
I guess there might be a difference between the 2nd and 3rd gen thermostat housings. it fits fine on my 2nd gen.
Lo-Fi Version Time is now: February 20th, 2025 - 1:38 AM
