> engine mounht and spacer axle mr2 issue
post Aug 3, 2011 - 9:35 PM
Needles
Joined Nov 18, '10
From montreal
im sitting lower than normal, i have 2 5sfe engine mounht and 2 custom for the mr2 tranny.
so i lost my bolt that hold the rear tranny custom mounth and , but before i notice this, first thing i heard was weird grinding noise when accelerating, alway same noise, grgegrgr, ,
so i realize what was that, ,
im sitting lower cause my custom mouhtn , and since i lost the rear tranny one, the engine camber much more backward.
that make the front axle getting closer to the tranny, and since im using spacer, the inside of the axle get into the spacer ,
that make the grinding weird noise i think, cause
when engine sit lower , the axle get closer to wheel,
im thinking of putting out the spacer, and soldering big nut in the tranny, cause all the other thing ive try the to hold the bold didnt hold for long
my question is , do i have to get all st205 engine mouhnt so its wont ever grind no more into spacer,
or,
took out the spacer and see ?
This post has been edited by Needles: Aug 4, 2011 - 9:03 AM
post Aug 3, 2011 - 10:05 PM
zeus83
Joined Sep 13, '08
From Kuala Lumpur, Malaysia
if im not mistaken you need the st205 driverside and rear engine mounts...
Lo-Fi Version Time is now: April 22nd, 2025 - 7:23 PM
