> Driveshaft trouble, have searched
post Aug 4, 2011 - 5:31 AM
Cs91
Joined Oct 16, '09
From Norway
Hello,
In need of a bit help here. Have just swapped a 3SGE into my AT200. But the passenger side driveshaft keep popping out of the wheelhouse. Or it popps out of the CV joint. Have watched some diagrams on toyodiy, but cannot find out if there should be a snap ring in the joint there? Cause there are none in my driveshaft assembly atm. Anyone familiar to how this CV joint should be rebuild? I took it apart yesterday and rebuild it and regreased, but the new grease just made it pop out even quicker! So now the car is just sitting going nowhere. And i can't even find the partsnr. on toyodiy....
Anyone that could help me with this?
This post has been edited by Cs91: Aug 4, 2011 - 5:47 AM
post Aug 4, 2011 - 7:35 AM
nsxtypeR
Joined Jan 3, '06
From The Netherlands
Are you sure you've got the correct driveshafts?
JDM ST205
post Aug 4, 2011 - 7:47 AM
brenton1919
Joined Feb 28, '11
QUOTE (Cs91 @ Aug 4, 2011 - 6:31 AM) *
Hello,
theres a rider bearing that holds that axle up that u will need to get or its just gonna keep breaking go to toyota and ask for a case sub-assy, drive part number 43045-20010
post Aug 5, 2011 - 11:24 AM
Cs91
Joined Oct 16, '09
From Norway
Thank you for the help guys, but i found out that my CV joint was missing a C-clip on the edge of the driveshaft that goes through the ball bearing. So there was nothing to keep the driveshaft from slipping through and out of the joint. Atleast i HOPE that is my problem. Got the ring from Toyota, and will try to install as soon as the rain settles...
Thanks again
post Aug 5, 2011 - 1:21 PM
jordisonjr
Joined Jan 20, '09
From Winnipeg
That should solve it.
When I got the clutch done in my GTS (5sfe) and went to drive off the axle popped out and they didn't know why, but after taking a closer look they said that one of the snap rings wasn't installed properly so the axle could easliy pop out of the transmission.
I'm thinking your tranny/axle would haev a similar set up.
My Celica!
Lo-Fi Version Time is now: April 21st, 2025 - 6:54 PM
