9 Pages V  < 1 2 3 4 5 > »
> FS: GT4 bumper, key ring light, etc., Cheap.
post Aug 14, 2011 - 6:43 PM
95celgt
Joined Oct 5, '03
From South TX.
knock sensor and ecu from the 94?
post Aug 14, 2011 - 7:08 PM
richee3
Joined Jun 29, '08
From Denver
PM'd.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Aug 14, 2011 - 8:27 PM
ricochet1490
Joined May 3, '11
From Ohio
If I could convince my stepdad to let me borrow his trailer this could be the start of my very own beams project haha. I mean I understand you can drive the redtop, and have the lexus, but given that you've already purchased the black beams and have a 5s, are you just tired of dealing with this car? jw - but GLWS anyway
post Aug 14, 2011 - 8:47 PM
richee3
Joined Jun 29, '08
From Denver
Yeah, you've pretty much hit the nail on the head. When I finally get the motivation to work on the car, I don't really get anything done. So I always end where I begin and that makes it difficult to care to go work on the car. Especially when the black BEAMS is so much nicer than my blue car and then there's the Lexus. It just makes it difficult to care about the Celica that doesn't run. I'm thinking about selling it and picking a Celica up that already runs. Just to make things easier, you know? I've had this car for a year and a half and basically, nothing has changed. It still sits in my yard and still doesn't run. I'm making enough money to get it running again, I just don't care to put the time into the car. It should go to somebody who will either invest the time to get it running or else invest the time to at least part it out or something.
1998 Celica GT-
BEAMS Swapped.
post Aug 14, 2011 - 8:50 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
i would jump on this if it was somewhat close.
post Aug 14, 2011 - 9:08 PM
Malhar95
Joined Jul 5, '09
From Katy/houston
QUOTE (stephen_lee @ Aug 14, 2011 - 9:50 PM) *
X2
post Aug 14, 2011 - 9:16 PM
250 for the car?????
post Aug 14, 2011 - 9:37 PM
richee3
Joined Jun 29, '08
From Denver
QUOTE (Malhar95 @ Aug 14, 2011 - 10:08 PM) *
X2
Lol split the cost of gas?
QUOTE (njccmd2002 @ Aug 14, 2011 - 10:16 PM) *
Yeah, $250 for the blue one.
1998 Celica GT-
BEAMS Swapped.
post Aug 14, 2011 - 10:30 PM
block
Joined Jul 27, '06
From Soda
What kind of bodywork is needed? Is the transmission still there? Good clutch? This might be a very good project for me.
post Aug 14, 2011 - 10:56 PM
richee3
Joined Jun 29, '08
From Denver
The car has several small dings, but no dents. The clearcoat is peeling on the hood, roof, and front bumper, so it needs paint. The dings are easily fixed when you go to paint. Both high beams are cracked but not leaking, somehow. I have replacement high beams from the parts car if somebody spends a little extra money. The body is straight, no accidents whatsoever. There is a small rust spot on the bottom of the driver's door but it's surface rust, not rusted through by any means. The transmission is good and the clutch was replaced about 10,000 miles ago, still good. As far as the motor work, we broke the rear motor mount when we were doing the BEAMS swap so we pulled the rear mount from this car to use on the BEAMS so this car needs a new rear mount ($50 from AutoZone or Ebay) and whoever buys this car, if they buy the motor, would probably be better to pull this motor out and start over from scratch, dropping it right back in. The shell has 186k on it and the motor is from a '98 Celica and has 196k, still running great when we pulled it out June 18th. I do not have any of the accessories hooked up (radiator, axles, power steering, clutch line, etc.) The motor will not start right now because the ECU isn't getting power. I haven't the slightest idea why, and I can't find the time or motivation to find out why. I'm sure I just missed a plug somewhere or something simple like that.
1998 Celica GT-
BEAMS Swapped.
post Aug 14, 2011 - 11:00 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
damit damit damit.
i want.
invent a teleportation machine and ill buy it NOW
post Aug 14, 2011 - 11:03 PM
richee3
Joined Jun 29, '08
From Denver
If I invent a teleportation machine and you buy it, I'll throw in the Celica for free.
1998 Celica GT-
BEAMS Swapped.
post Aug 15, 2011 - 12:19 AM
block
Joined Jul 27, '06
From Soda
Well I'm thinking about dropping the motor from my 94 in it since my wife don't want me selling the car. She wants a 3sgte in the current celica. Are the axles on? Tranny still in place? I'll talk to the wife as this would be great.for learning and winter.
post Aug 15, 2011 - 6:35 AM
richee3
Joined Jun 29, '08
From Denver
The motor and tranny are in place, but the axles are still in the boxes in my garage. I need to pull the carrier bearing bracket from my parts car to go with the motor in case somebody buys the motor with the shell.
1998 Celica GT-
BEAMS Swapped.
post Aug 15, 2011 - 7:33 AM
block
Joined Jul 27, '06
From Soda
How much with motor? With new axles? Both front needed new axles? What about wheel bearing? That would still need replaced?
post Aug 15, 2011 - 10:39 AM
spy00005
Joined May 15, '09
From yonkers, NY
hey do you have the headlight rubber and the clips that hold them in place? if so how much shipped to 10705. thanks.
*Thing i want for my car(i wish i had money)*
-full gt4 front end conversion (DONE :) JUST NEEDS PAINT(next on to do list) -new seats all around
-riser blocks -fog lights -new radio and speakers all around
-full bodykit splitters and sideskirts to go with conversion (just needs fitting and painting)
-nice rims (Got TC rims and painted them white)
-light blue tint (next step will do this right after i get my paint job)
WTB Reasonably priced
Projectors just Lows
post Aug 15, 2011 - 11:49 AM
richee3
Joined Jun 29, '08
From Denver
It would still need new wheel bearings but I have several other parts. PM'd.
Spy, the headlights are all called for.
1998 Celica GT-
BEAMS Swapped.
post Aug 15, 2011 - 12:03 PM
spy00005
Joined May 15, '09
From yonkers, NY
not the headlights just the rubber and clips but if those are called for its all cool.
post Aug 15, 2011 - 2:14 PM
richee3
Joined Jun 29, '08
From Denver
Yeah, I just figured I would leave the headlights intact, complete with the rubber rings.
1998 Celica GT-
BEAMS Swapped.
post Aug 15, 2011 - 10:36 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Hey how about an accelerator cable?
2001 Solar yellow Lexus IS300
Lo-Fi Version Time is now: November 22nd, 2024 - 1:50 PM
