> VSV Valve
post Aug 6, 2011 - 4:07 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
Hello everyone,
I have had problems with my Evaporation system, and my mechanic said he would need to replace the charcoal canister and the VSV Valve. I have a tech manual that I've been looking through and I've been searching on the web and found a good deal on the canister at toyota parts barn. I found another name for the charcoal canister, which is the vapor canister, and I'm thinking that the VSV Valve migh have another name. Or is the VSV valve included in the vapor canister?
post Aug 7, 2011 - 1:04 PM
toyotatech3
Joined Jul 30, '04
From colorado
vacuum switching valve
post Aug 7, 2011 - 5:56 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (toyotatech3 @ Aug 7, 2011 - 2:04 PM) *
Okay I know what its stands for, but do you know if it is included with the vapor canister? or if it goes by a different name?
post Aug 7, 2011 - 7:44 PM
toyotatech3
Joined Jul 30, '04
From colorado
sorry didnt read it all! no it does not come with the canister, at least not at a toyota dealer. thats the only name i know of.
post Aug 7, 2011 - 9:22 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Bi-metal vacuum switching valve (BVSV) isn\'t part of the charcoal canister -- if it\'s the one for the evaporation system, it\'s connected to the charcoal canister by a vacuum line but is actually screwed into the same portion of the head as the water temperature sensor.
90925‑05068 -- $53 from 1sttoyotaparts.com
It\'s a blue-green plastic piece with two vacuum lines attached to it. It\'s the one on the right side of this photo (not the circled item).
Easy to test, I used a drink box straw.
A) Cool the BVSV to below 35°C (95°F) with cool water. Blow air into the top port and check that the BVSV is closed.
B) Heat the BVSV to above 54°C (129°F) with hot water (I placed it upright in a pot with the water up to the hex head). Blow air into the port and check that the BVSV is open.
Replace if it fails, or re-install if it passes. Use a mid-strength threadlocker to seal it, Three Bond 1324 or equivalent.
This post has been edited by Galcobar: Aug 7, 2011 - 9:26 PM
post Aug 8, 2011 - 12:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah its the one on the right with teh 2 hoses, you cant really see both of them cause they are on top of each other. do the above test to see if its working, you really dont need to change the charcoal canister that will be $$$
2001 Celica GT-S Turbo
1997 Supra TT 6speed
1997 Celica 3MZ/1MZ swap
1990 Celica All-Trac
post Aug 10, 2011 - 9:00 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
QUOTE (Smaay @ Aug 8, 2011 - 12:55 PM) *
Thank you all for your quick responses, I just learned a lot about the evaporation system. My mechanic said I needed to get both replaced though. Is it possible that the valve malfunctioning could do damage to the vapor canister? This car is at 145,000 miles.
post Aug 10, 2011 - 11:07 PM
Galcobar
Joined Mar 3, '05
From Richmond, B.C.
Not really, the charcoal canister is just a filter in a can. Activated charcoal, actually.
The canister is cleaned by firing 294 kPa (3 kgf/cm2, 43 psi) of compressed air into port A (port on the same side as the bracket) while holding port B closed. The air will come out the bottom of the canister, so you'll want it disconnected from the system. Testing is pretty simple: blow in port A and air should flow out of the other ports. Blow into port B and it should not. Unless the canister is cracked or activated charcoal comes out the ports when you're blowing into them, it's fine.
Ask your mechanic what's actually wrong with it.
post Aug 11, 2011 - 2:55 PM
Smaay
Joined Dec 8, '03
From Lancaster CA
yeah it sounds like he is trying to squeeze money out of you
post Sep 11, 2011 - 3:07 PM
DIONYZUZ
Joined Oct 29, '09
From Chicago
I started doing some DIY work on here, I looked for the location of the vsv for evap on my repair manual and its supposed to be some where under the throttle body, but I do not see it. I also have tried finding it with your pic but I still don't see it,. I've taken apart some components like the air box and cruise control actuater to put in a cai and I still don't see it please help
Lo-Fi Version Time is now: February 21st, 2025 - 12:17 PM
