> What part is this??
post Aug 7, 2011 - 4:39 PM
6G96GT
Joined Jan 20, '08
From East Coast
Hey guys, this switch or sensor (the one with the green wire coming out of it) apparently was pretty worn out and snapped off when I was pulling out a wire from the distributor cap. Does anyone know what it is? It sticks straight up off the pipe that connects into that side of the cylinder head.
A closer look...
This post has been edited by 6G96GT: Aug 7, 2011 - 4:47 PM
post Aug 7, 2011 - 4:41 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Hmm, could you possibly post a pic?
-Ryan
post Aug 7, 2011 - 4:47 PM
6G96GT
Joined Jan 20, '08
From East Coast
Sorry bout that, just did.
post Aug 7, 2011 - 4:56 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Wow, I really don't know what that is. Sorry. Hope you find out soon though.
-Ryan
post Aug 7, 2011 - 5:15 PM
enderswift
Joined Jul 12, '08
that looks like a coolant temp sensor, If i remember right. This is a 5s correct?
post Aug 7, 2011 - 5:19 PM
6G96GT
Joined Jan 20, '08
From East Coast
Yes it is a 5sfe. I ran the engine with that sensor broken and my temp gauge worked fine. Is that the same sensor-to-gauge?
This post has been edited by 6G96GT: Aug 7, 2011 - 5:20 PM
post Aug 7, 2011 - 5:27 PM
Kwanza26
Joined Dec 27, '03
From Nor Cal
Generally 2 wires on that back housing in coolant temp. One wire is fan switch. The gauge sensor is typically much smaller and is single wire... usually between head/block water passage. The engine will run fine generally with a bad coolant temp sensor when warm... ****ty when cold.
post Aug 7, 2011 - 5:30 PM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (Kwanza26 @ Aug 7, 2011 - 6:27 PM) *
Yes temp sensor for cold start, mine would not start when it was cracked, it is 15 dollars at autozone
post Aug 7, 2011 - 6:17 PM
6G96GT
Joined Jan 20, '08
From East Coast
thanks guys, so I can run it now without any worries?
Lo-Fi Version Time is now: November 26th, 2024 - 10:02 AM
