31 Pages V  « < 24 25 26 27 28 > »
> Enders swap, Update 11/29/19
post Apr 10, 2016 - 5:57 PM
enderswift
Joined Jul 12, '08
QUOTE (richee3 @ Apr 10, 2016 - 1:00 PM) *
Clean install! Wish I could see it at the meet next month.
I'm reserving hope that you will come to your senses
QUOTE (navseal345 @ Apr 10, 2016 - 1:33 PM) *
First dibs on a ride at the meet! Damn so jelly.
no problem at all
QUOTE (4-eyed-freek @ Apr 10, 2016 - 3:44 PM) *
Fantastic job! The attention to detail is manufacture quality. If I don't see this car at the meet next month i'm going to throw a fit.. laugh.gif
Kind words, thank you. And I fully intend to make it there
post Apr 10, 2016 - 8:04 PM
I'm a fan of the green LED, nice job with the clean install.
post Apr 10, 2016 - 8:15 PM
Box
Joined Feb 23, '12
From Warrior, AL
I think you'll see the benefits of the water injection soon with hotter weather around the corner. Nice job on everything too.
2001 Miata LS 5-speed
post Apr 10, 2016 - 8:54 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
at first I thought I was looking at nozzles for a fire suppression system hahaha
although its not a fire suppression system the install of the injection kit looks mint!
エキサイティングカーレーシングチーム!
post Apr 11, 2016 - 5:32 PM
enderswift
Joined Jul 12, '08
QUOTE (Batman722 @ Apr 10, 2016 - 8:04 PM) *
QUOTE (Box @ Apr 10, 2016 - 8:15 PM) *
QUOTE (Tigawoods @ Apr 10, 2016 - 8:54 PM) *
Its a long way before I can justify a suppression system! Frankly I dont think I'll ever build a balls out track car that would warrant it. I'm more of a track capable street car kind of guy
post Apr 24, 2016 - 10:10 PM
enderswift
Joined Jul 12, '08
BOOST CONTROLLER INSTALLED!!!!!!1!!!!!!11!!!!!
almost 4 years after the initial swap I finally have full control over the turbo smile.gif I've been holding off until everything else was in place to make the most of the power:
Superstrut suspension to maximize tire contact patch - check
Rebuilt transmission with helical LSD upgrade - check
Watermethanol injection to protect engine from boost spikes - check
With these things in place I can make reliable power, and put it down consistently.
So now I am boosting juuust below fuel cut. There is still some tuning to do before I find the perfect balance between spool and peak boost in all gears, but so far the increase in power is really really satisfying biggrin.gif 5th at 70+ mph has now been upgraded to a competent passing gear
Of all the things I've installed on this car, this was the easiest. Everything just came together really easy. Wiring was easy, routing was easy, and mounting was easy. The only thing that took a little time was bolstering the vacuum source for all of the map sensors. I wanted to increase the diameter of the hoses and tap in at the back of the manifold to ensure a good signal. This wasn't needed for the install though. The car now has a total of 4 map sensors serving all of the guages and controllers and such rolleyes.gif
Phase 2 of project ST205 is officially complete. Time to enjoy the car for a while... and get ready for PHASE 3
This post has been edited by enderswift: Apr 24, 2016 - 10:16 PM
post Apr 24, 2016 - 10:20 PM
wow, im amazed, never tought you would go this route.
post Apr 24, 2016 - 10:21 PM
navseal345
Joined Aug 17, '09
From Millard, Omaha, Nebraska
post Apr 24, 2016 - 10:32 PM
enderswift
Joined Jul 12, '08
QUOTE (njccmd2002 @ Apr 24, 2016 - 10:20 PM) *
I think you'll like my approach. It's gonna be different from what others have done
This post has been edited by enderswift: Apr 24, 2016 - 10:33 PM
post Apr 24, 2016 - 10:45 PM
Box
Joined Feb 23, '12
From Warrior, AL
*makes popcorn and pulls up the La-Z-Boy*
It is nice being able to pass while in overdrive.
post Apr 25, 2016 - 6:58 AM
4-eyed-freek
Joined Apr 17, '10
From U.P. michigan GO STATE
Glad you are enjoying the EBC, once dialed in they make for a vast improvement over factory spool up!
It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Celica: The name is derived from the Spanish word for "heavenly" or "celestial".
Back-2-Back July COTM 15&16
post Apr 25, 2016 - 10:02 AM
enderswift
Joined Jul 12, '08
there's already a big improvement. Toyota took linear power build up a little too seriously. I prefer the sudden rush of torque as the turbo spools, it's just more fun. The tricky part with tuning is the fact that my cutout causes the controller to overshoot it's target. I'm gonna have to setup a separate boost profile for when it's open.
post Apr 25, 2016 - 11:05 AM
richee3
Joined Jun 29, '08
From Denver
You and Skyler are leaving me behind. Sounds like I need to wrap the Poopra up and get back to work under the hood of the Celica...
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Apr 25, 2016 - 12:37 PM
enderswift
Joined Jul 12, '08
owning a supra puts you ahead by default
post Apr 25, 2016 - 12:46 PM
richee3
Joined Jun 29, '08
From Denver
Owning a GT4 in the States and/or having the balls to convert yours puts you guys leagues ahead of me.
1998 Celica GT-
BEAMS Swapped.
post Apr 25, 2016 - 2:08 PM
Box
Joined Feb 23, '12
From Warrior, AL
The modesty level is too much.
post Apr 25, 2016 - 3:55 PM
bloodMoney
Joined Aug 4, '06
From Chicagoland
QUOTE (richee3 @ Apr 25, 2016 - 12:46 PM) *
Having a toy in general puts me way behind the pack. I'm just trying to get my junk running.
~bloodMoney
post Apr 25, 2016 - 6:09 PM
navseal345
Joined Aug 17, '09
^^^ Haha.
Oh wait, damn it.
post Apr 25, 2016 - 6:59 PM
enderswift
Joined Jul 12, '08
QUOTE (bloodMoney @ Apr 25, 2016 - 3:55 PM) *
Says the ST165 altrac owner...Recent turbocharged lancer owner....Current lexus land yacht owner biggrin.gif
This post has been edited by enderswift: Apr 25, 2016 - 8:08 PM
post Apr 25, 2016 - 10:09 PM
Bitter
Joined Mar 11, '06
From Way South Chicago
I'm 99% the Altrac is hers and she'd cut his toes off one by one with piano wire if he tried to say otherwise.
Lo-Fi Version Time is now: February 22nd, 2025 - 4:05 AM
