Enders swap, Update 11/29/19 |
Mar 10, 2012 - 1:25 PM |
Enthusiast Joined Apr 3, '10 Currently Offline Reputation: 3 (100%) |
As a fellow 6GC owner living in Chicago wanting to do a swap... How are you going to get around emissions?
Mar 10, 2012 - 9:47 PM |
Enthusiast Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
Any chance of an update? No real update unfortunately since school keeps me pretty busy. I'm getting a nice fat tax return though, and spring break starts next week. So it wont be much longer before I have the short block finished. at which point I'll post an update that even photobucket will notice. Speaking of buckets, the ones you sent me worked perfectly; so thanks again QUOTE As a fellow 6GC owner living in Chicago wanting to do a swap... How are you going to get around emissions? I think your best bet would be to buy a celica that is 1995 or older This post has been edited by enderswift: Jan 14, 2013 - 7:20 PM -------------------- |
Mar 11, 2012 - 2:01 PM |
Haha I guess I'm no longer on the fence about going to the meet lol. I really want to know! I want to throw a 2GR in mine sooo bad.
Mar 11, 2012 - 4:47 PM |
Enthusiast Joined Aug 17, '09 From Millard, Omaha, Nebraska Currently Offline Reputation: 1 (100%) |
You still plan on going AWD after a little while correct? And there is modification required for that, correct? Still cant wait to see this Celica at a Midwest Meet!
Mar 11, 2012 - 5:48 PM |
Haha I guess I'm no longer on the fence about going to the meet lol. I really want to know! I want to throw a 2GR in mine sooo bad. good, these midwest meets need to keep growing. And a 2gr sounds pretty awesome QUOTE You still plan on going AWD after a little while correct? And there is modification required for that, correct? Still cant wait to see this Celica at a Midwest Meet! Sure am. The extent of the modification is limited to constructing custom subframe mounts, since the rear usdm floorpan is different from that of an actual gt4. Its nothing crazy though. -------------------- |
Mar 11, 2012 - 6:27 PM |
Awesome.
Mar 16, 2012 - 1:27 PM |
I'm glad the buckets worked out for you I can't wait to see this thing fired up!
Mar 20, 2012 - 9:23 PM |
Hello everyone,
Many interesting and time consuming things have been keeping me busy the last few months so unfortunately there hasn't been too much progress on the rebuild. Nevertheless it is now spring break, and I have a little spare cash to burn. So I have been ordering parts and finally tore into the bottom end. Observe: the Toyota fipg stuff is awesome at sealing and preventing leaks. But damn does it fight you when you're trying to take everything apart I try to make a habit of threading bolts right back into their respective parts to avoid confusion later, which is the case with this upper oil pan After a few hours I had my work bench setup for the next round of rebuilding, complete with a new template to keep me organized and a number of parts ready for a round of cleaning. Its usually a good idea to put cuts of hose on the rod bolts to prevent them from scratching the cylinder walls during removal Having done that I was happy to see the cylinder walls were in really good condition. No scuffs, scratches, or cracks anywhere Maybe this motor wasn't so badly abused after all. the rod bearings on the other hand show a little wear from what can only be a lot of cold starts. Nothing to be alarmed about though, and there were no signs of oil starvation. I'm assuming these are multi-layer bearings from the way the wear pattern looks The block looks relatively clean on the inside, which is surprising considering the cylinder head was absolutely filthy. Thankfully all of the crank journals look in good shape, but I'm still going to get them polished in preparation for a new set of bearings Overall these photos don't depict much progress, but the fact of the matter is that the bottom end is much simpler compared to the cylinder head. Way fewer parts (most of which have convenient stampings), and way fewer surfaces to tolerance. Therefore things should progress at a much quicker pace compared to before (money permitting) In the coming weeks I plan to get the block hot tanked, crank polished, cylinders honed, and a number of replacement parts in. So a short block should be complete by mid May, at which point I'll be focusing my attention on all of the ancillary assemblies. The ultimate goal being to have a long block complete by mid July. This post has been edited by enderswift: Dec 22, 2012 - 10:06 AM -------------------- |
Mar 21, 2012 - 6:30 AM |
Mar 21, 2012 - 7:40 AM |
Enthusiast Joined Feb 2, '07 From Berlin, WI Currently Offline Reputation: 18 (100%) |
looks good. can't wait to see it finished.
-------------------- *1997 Celica ST - 3SGE Greytop BEAMS *1977 Celica RA29 - Classic Cruiser *2005 Matrix AWD - dedded but still hanging around like a ghost 2019 Rav4 XLE Premium - Sports mode is fun. |
Mar 26, 2012 - 10:58 PM |
Enthusiast Joined May 16, '10 From Raleigh Currently Offline Reputation: 12 (100%) |
I love the wrinkle paint job on that valve cover! Wish you had posted this thread in Forced Induction! You've been hiding!
Apr 2, 2012 - 8:32 PM |
QUOTE I love the wrinkle paint job on that valve cover! Wish you had posted this thread in Forced Induction! You've been hiding! thanks bud, I was going for more of an oem look and I'm glad it turned out alright. I really suck at painting haha small update: Got some parts in. Oil pump, water pump, belt tensioner, the enormous thermostat, pcv valve, and some other stuff. Its a funny feeling when you spend $400 dollars but the package is really small haha. Money well spent though and I really cant say enough good things about Lithia Toyota, amazing customer service. All I have left to buy is the bearings and rings. Everything else is ready -------------------- |
Apr 2, 2012 - 8:50 PM |
Hurry up! Lol.
Apr 17, 2012 - 6:22 PM |
Necesito update sir.
Apr 27, 2012 - 11:03 PM |
QUOTE Necesito update sir. Oh believe me, no one wants to see updates to this thing more than I do haha, but the last few weeks at school have been absolute insanity. The only things I've done are limited to a few minor refurbishings that aren't even worth talking about. I'm graduating so there will be many updates when I start working. oh yea the two idler bearings came in for only $30, so thanks for letting me know about B&D This post has been edited by enderswift: Apr 27, 2012 - 11:05 PM -------------------- |
Jun 27, 2012 - 8:25 PM |
Hey guys,
long time no update. Things have been pretty hectic: I've graduated, I've started a career, and I had to see some other projects through. Namely this: Everything is done now. So expect big updates soon because I finally have a steady income and free time woooo! This post has been edited by enderswift: Oct 3, 2012 - 12:30 PM -------------------- |
Jun 29, 2012 - 2:48 PM |
Enthusiast Joined Aug 4, '10 From Massachusetts Currently Offline Reputation: 0 (0%) |
can't wait for updates!
Jun 29, 2012 - 6:48 PM |
Enthusiast Joined Dec 9, '08 From Blainville Currently Offline Reputation: 4 (100%) |
Hey guys, long time no update. Things have been pretty hectic: I've graduated, I've started a career, and I had to see some other projects through. Namely this: Everything is done now. So expect big updates soon because I finally have a steady income and free time woooo! Are you in the FSAE? |
Jun 29, 2012 - 7:44 PM |
You have two weeks to get this engine in your car and come to the meet. That is all.
Jun 30, 2012 - 10:18 AM |
Enthusiast Joined Mar 7, '10 From Ft. Lauderdale Currently Offline Reputation: 9 (100%) |
You have two weeks to get this engine in your car and come to the meet. That is all. ^this -------------------- |
Lo-Fi Version | Time is now: November 22nd, 2024 - 6:10 PM |
