> running vac line for boost gauge...
post Aug 18, 2011 - 4:42 PM
94_gt4
Joined Jul 27, '11
From calgary
so im going to throw the boost gauge in but i dont know where to run the hose into the cabin, i know where to tap it, but how to get it in the cabin?
post Aug 18, 2011 - 4:53 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
you can route it the same way you would an amp power wire, but make sure it cant be pinched, or rubbed through
post Aug 18, 2011 - 5:05 PM
94_gt4
Joined Jul 27, '11
From calgary
i figured i could do that, its not a big deal that the hose is a bit longer because of it? will the reading still be accurate with a longer hose?
post Aug 18, 2011 - 7:58 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
its still going to read pretty accurate
post Aug 19, 2011 - 6:00 PM
ST205WRC
Joined Dec 30, '10
From amarillo texas
im not sure how much the LHD and RHD firewalls differ from each other but on the RHD under the drivers side there is a hole that you can use to run it through. it has a rubber grommet in it already with wires so you should be able to find it (if its there on LHD). and ^^he is right its should still be accurate pressure is felt equally through the entire system.
post Aug 19, 2011 - 9:09 PM
94_gt4
Joined Jul 27, '11
From calgary
pic? i dont see any grommet on the RHD side. there is one on the passenger(LHD side) that i ws going to put it through
post Aug 19, 2011 - 10:52 PM
ST205WRC
Joined Dec 30, '10
From amarillo texas
for a left hand drive car it would be on the passenger side its below and a little to the right of the master cylinder area.
post Aug 20, 2011 - 12:07 AM
94_gt4
Joined Jul 27, '11
From calgary
i have a rhd, is it different?
post Aug 20, 2011 - 8:18 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
oh then it should be on the drivers side, down and to the right of the master cylinder area. lol
i went back a read my previous post and it didnt make sense. if the car is LHD and the hole is on the passenger side then how is the master cylinder right above it lol
post Aug 20, 2011 - 5:42 PM
94_gt4
Joined Jul 27, '11
From calgary
if its the one i think youre talking about, theres no way of getting anything in it. anyways, i just ran it through the same place on the passenger side as i did my amp power wire. running stock psi between .8 and .9 bar...
post Aug 21, 2011 - 4:49 AM
ST205WRC
Joined Dec 30, '10
From amarillo texas
yeah it should be .9 in all gears but 1st that is .7, once you put an exhaust and downpipe on it itll go up those. i think toyota did it on purpose, making there wastegate too small so its over boosts once you open up the exhaust. itll go up but it has yet to hit fuel cut for me. i get .9 in 1st and 1.1 in all others.
post Aug 21, 2011 - 11:22 AM
94_gt4
Joined Jul 27, '11
From calgary
at what bar/psi does fuel cut hit at? youre right, i get .7 bar in first gear. when i get my boost controller i want 16 psi, that equals about 1.150 bars, no?
Lo-Fi Version Time is now: November 23rd, 2024 - 12:02 AM
