> ST or GT simple way to tell?
post Aug 20, 2011 - 8:17 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
Looking at a 95 liftback online, it's got the oe bbs wheels, no sunroof, black cloth interior and a manual trans, no engine pic or I'd know right off. Any way to tell without looking at the motor?
post Aug 20, 2011 - 8:20 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
ST has rear drums. really the only way to tell other than engine and badging
post Aug 20, 2011 - 8:39 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
It's a GT, sweet. Looks like I'll finally have a car I've wanted for years.
post Aug 20, 2011 - 8:50 PM
dustin15brown
Joined Aug 17, '03
From Bloomington, Indiana
not necessarily. just because it has disc brake rears doesn't mean it's a GT. A LOT of people convert their rear drums to disc brakes.
post Aug 20, 2011 - 8:55 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
QUOTE (dustin15brown @ Aug 20, 2011 - 9:50 PM) *
I confirmed that it's a GT by the chassis code. Side note, I love your car, are those 5th gen mirrors?
post Aug 20, 2011 - 9:03 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
but the chances of someone liking their car enough and knowing enough to change the rears to a disc should know if its a gt/st
post Aug 20, 2011 - 9:09 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
QUOTE (stephen_lee @ Aug 20, 2011 - 9:03 PM) *
Yeah, owner is oblivious to anything car related it seems. Another side note, your V6 swap has me drooling.
post Aug 20, 2011 - 10:11 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
those are the people you can usually talk down..
and i know it still excites me when i work on it lol smile.gif thanks!
post Aug 21, 2011 - 1:01 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
post Aug 21, 2011 - 1:45 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
that doesnt always mean a bad thing..
some cases salvage may mean it was in a flood and water got inside, or a engine bay fire or any collision where the airbags went off causeing a lot of "damage" that is a simple bolt back in kinda thing.
my daily and project are both "salvage" my daily was in a front end collision that made the airbags go off slight misalignment of body panels have been a side effect
my project? the airbags went off. i cant find ANY other damage. and i tore that thing to the frame.
salvage title = good point in lowering the price wink.gif just make sure to check that...
the front end lines up
check the frame rails/fender aprons(where the upper fender bolts to) in the engine bay carefully. if it was in a serious front end collision u will be able to tell by these two parts
on the pass side try to lift the airbag cover. if you can they went off..
check all the windows for the TOYOTA markings. it may have been vandalized(broke all the glass/mess up the paint = totaled w/o any REAL damage)
water damage? if you can smell mold inside its was probably this. but other than that as long as the ecu wasnt damaged or got in the engine(if it runs ur safe)
post Aug 21, 2011 - 4:33 PM
al94st
Joined Dec 30, '09
From Wilmington, NC
how much are you looking to pay and does it have to be a gt?
post Aug 21, 2011 - 7:23 PM
99celicanancy
Joined Aug 21, '11
From Naperville, Il
ew drum brakes....
post Aug 21, 2011 - 9:30 PM
celica-s
Joined May 9, '11
From Manila, Philippines
ST chassis code AT200 - - - -
no abs?
7afe engine
No foglamps
post Aug 22, 2011 - 12:42 AM
Goonter
Joined Nov 27, '09
From Canada
QUOTE (celica-s @ Aug 21, 2011 - 9:30 PM) *
no abs?
7afe engine
No foglamps
Weren't fog lamps option??
post Aug 22, 2011 - 3:42 AM
Malhar95
Joined Jul 5, '09
From Katy/houston
My car doesn't have abs nor foglights and its a gt
post Aug 22, 2011 - 9:46 AM
whitewhisky
Joined Oct 25, '10
From Ankara - Turkiye
my celica 1994 / AT200 - 7afe but the rear brakes original disc and abs standart confused.gif
This post has been edited by whitewhisky: Aug 23, 2011 - 2:31 AM
Celica from TURKIYE
post Aug 22, 2011 - 10:29 AM
KaneO
Joined Aug 16, '11
From Australia, Vic, Portland
I believe the GT has a beta/different looking wing compared the the ST as well? I have a ZR (an Aussie GT) that has no fog lamps? Were they optional or removed in its life time?
post Aug 23, 2011 - 1:03 AM
celica-s
Joined May 9, '11
QUOTE (Goonter @ Aug 22, 2011 - 1:42 AM) *
no abs?
7afe engine
No foglamps
i believe its an optional equipment. my celi didn't come with it. no brackets, no switches and harness. so i assume the first owner didn't opt. to have it.
post Aug 23, 2011 - 5:37 PM
Ziptied
Joined Aug 20, '11
From Charleston, SC
I'm looking to spend no more than 2500, seems fair price for a decent gt liftback
This post has been edited by Ziptied: Aug 23, 2011 - 5:37 PM
post Aug 24, 2011 - 2:28 PM
RabidTRD
Joined May 31, '11
From Rochester, NY
QUOTE (Ziptied @ Aug 23, 2011 - 6:37 PM) *
I only spent 2400 on mine. It's a 94 GT-S with 5 speed. (Guy didn't know it had the solid struts or he probably would have asked more.) Mine had only 148k miles when I bought it.
If you're only expecting to pay $2500 for one, make sure you check it out. Most that are that cheap need work. Mine needed all new gaskets, new filler neck, rust fixed, spark plug tubes re-sealed, tune up, new rad... so look at it carefully.
Lo-Fi Version Time is now: November 23rd, 2024 - 4:03 AM
